radiator for 390?
Old Aug 14, 2013 | 10:02 AM
SuperDuty93's Avatar
SuperDuty93
radiator for 390?
Hi all. I'm looking into a radiator for my 390. Anyone have any luck with a champion radiator? I was thinking of a champion with the dual electric fan option they give.
Old Aug 14, 2013 | 04:40 PM
Roger Carter's Avatar
Roger Carter
I have a 3 row Champion on an otherwise stock '96 Bronco. I installed it in June 2011 and until a week ago it worked flawlessly. A week ago it sprung a leak between a tube and the header. I called Champion, followed their warranty directions and have a new radiator on the way. That quick and that easy.
I wish I hadn't had a problem, but have to give Champion credit for their warranty and handling of the issue.
The Champion appeared to be a solid unit. It was a direct replacement for the original and works well. I wouldn't have any qualms about buying from them again.
Roger Carter
Old Aug 14, 2013 | 04:44 PM
EP145's Avatar
EP145
Yes, I live in Phoenix and put a 4 row champion radiator off eBay in last month and it fit prefect and works well. I also have AC and have had no problems. I'm running a clutch fan with a stock shroud.
360FE 4speed manual.
Old Aug 14, 2013 | 07:08 PM
SuperDuty93
Thanks guys! I was thinking of going with their dual electric set up. Any thoughts?
Old Aug 14, 2013 | 07:12 PM
Roger Carter
Sorry, can't help you there. I am using the stock fan and shroud on the Bronco.
Roger Carter
Old Aug 14, 2013 | 07:19 PM
keiths78f150's Avatar
keiths78f150
I don't see the benefits on electric fans to be honest. With a good radiator, a mechanical fan will work just fine. The only thing I think about with electric fans is that they can quit and then you are f'ed.
Old Aug 14, 2013 | 10:12 PM
EP145's Avatar
EP145
For a driver my mech fan is working great. If you go with electric fans you will need to up grade your electrical system.
Old Aug 14, 2013 | 11:12 PM
SuperDuty93
Thanks for all the replies. Yea I only see the fans dying and then over heating myself haha tats what ive always questioned. But to clarify, this 390 is in my 59 f100. I have a highboy an since most people in this section of fte have a FE engine it made sense to post this on here. And this truck isn't a DD its a semi drag truck/show truck.
Old Aug 15, 2013 | 01:18 AM
EP145's Avatar
EP145
Here is some info on electric fans under the tech info area.
https://www.ford-trucks.com/forums/1...mpilation.html
Old Aug 15, 2013 | 08:51 PM
Blue and White's Avatar
Blue and White
I've heard good things about Champion but never run one. In my '78/400M I recently installed a 3 core copper/brass radiator from AZ. This is the factory "extra cooling" radiator. No problem with 95 and occasional 100 degree temps. I don't know how it would fit your '59 and same comment applies to the Champion.
Old Aug 15, 2013 | 09:55 PM
EP145's Avatar
EP145
My friend has a 60 f100 and we measured mine which the guy stated would fit in a 60 with modification and it was going to a lot of modification to make it work. It might be better to have one made for you truck instead of a champion.
Old Aug 16, 2013 | 01:09 AM
SuperDuty93
The guys at champion found one that would fit my truck almost right out of the box I'm just curious as to fans and the radiator itself.
Old Aug 16, 2013 | 03:15 AM
keiths78f150
I am tellin ya, dont waste your money on the fans just yet. IF you want to get them(I wouldnt) just do a swap off a thunderbird or whatever. They are cheap in a junkyard and easy to install.
Old Aug 16, 2013 | 11:11 AM
Roger Carter
I'll toss my 2 cents worth about electric fans, based on my experiences.
A puller fan seems to work better than a pusher.
Two smaller diameter fans are usually better than one larger fan, but make the two fans as large as possible.
Use a shroud that covers the entire radiator.
A specific purpose fan, puller or pusher, works better than most "either / or depending on how they are mounted" types.
Fans require a lot of power. Make sure the truck's charging system, wiring and fan control system are up to the task.
Again, these are based on my experiences. Hope they help.
Roger Carter
Old Aug 16, 2013 | 11:15 AM
SuperDuty93
Thanks for all your input. For now I'm just going to do a clutch fan and see how it cools. Then maybe later ill find electric ones at the junk yard.
