M F T issue
Old Aug 13, 2013 | 07:06 PM
shatfieldj's Avatar
shatfieldj
M F T issue
Hi all. My truck is just over 1 month old. I just found out that my mft is not working properly. When I go into services, and then ask for directions, I get nothing. The voice tells me that they can't locate my vehicle. I tried several master resets with no results. I called ford and they told me to do a master reset. Told him I did and he checked my account. Said everything is good, it should work. He said it might be a g p s issue with the truck and to take it to the dealer. Has anyone had this problem? Any other ideas before I make the service call. Thanks.
Old Aug 13, 2013 | 09:35 PM
KJ Smith's Avatar
KJ Smith
I may be off base, but MFT is My Ford Touch.
I think you just have Sync.
None the less, you should still be able to get services. That is a paid subscription at some point. I don't remember how long.
Most people will tell you to disconnect the battery for 30 minutes or so and then give it a try.
Old Aug 14, 2013 | 09:23 AM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Hi shatfieldj,
I'd recommend a fuse pull instead of a battery disconnect. The SYNC fuse is a 15 amp, located in position #2 under the passenger compartment panel (page 315): http://www.motorcraftservice.com/pub.../13f12om3e.pdf
I would also advise verifying that your phone is working properly, as SYNC borrows the cellular module in your device to communicate with SYNC Services. Try removing the battery form your phone for a minute, then reconnecting. Also, make sure the in-call volume is all the way up on your phone. Let me know how it goes!
Antonio
Old Aug 14, 2013 | 04:46 PM
shatfieldj's Avatar
shatfieldj
KJ. You are correct. I just have the basic sync with the 4.5 screen. Antonio, I have an I phone. Don't know how to pull the battery. I will try to pull the fuse. This is the same phone that I used with my 13 explorer that I traded for the truck. It worked well with the explorer. No problems at all. Every thing works except the directions part. Looks like a trip to the dealer is in order. Thanks.
Old Aug 15, 2013 | 02:36 PM
shatfieldj's Avatar
shatfieldj
Update:
Just an update on my issue. Went on the sync my ride page and was looking around. To make a long story short, it turns out that I failed to activate the sync service. Once I did all is ok now. Don't know how I missed that. I even called ford and they said my account was active, that's why they thought some thing was wrong. Anyway it's working now. I'm a happy camper. Mabey this will help someone else out. Cheers.
trajones123
Oct 29, 2012 03:40 PM
ryutzy
1997 - 2003 F150
Jan 24, 2011 11:56 PM
daggerNC
Sep 30, 2008 11:22 AM
bigworm
Electrical Systems/Wiring
Aug 20, 2006 06:47 PM
nsshull
Aug 14, 2005 11:14 PM
