Was using the Torque app the other day, checking it out(over the weekend). When I scanned my X the were no fault codes stored, but when I ran test results I came up with this and for the life of me can not find out what it means TID:$04 CID:$21- High sensor voltage for switch time calculation- min 119 max 768- current 0. It says Not OK. It also says the same for
TID:$04 CID:$21. I have googled and either I am doing something wrong(which is very possible) or there is no answer that I am finding. As a side note if anyone is using Torque app is there a way to make to make the dial/gauges larger on a tablet. My eyes don't work like they used too
The app is actually really good. If you hold down a gauge you do have some options - but I believe to change the style of gauge (analog to digital, etc) or size of the gauge it has to be deleted and added back. When adding back you get the choice of size along with type of gauge display. Make sure you get the extended Ford PIDs as they add a considerable amount of available data.
Thanks I finally figured that out, delete gauge, add back, choose display option, and then resize. What I would really like to know is the generic codes that failed and what they may mean TID:$04 CID:$11 and the other listed above, or are these things in the Torque app that don't really apply to the X?
Thanks, torque is a great app for the price. With a tablet, the gauges are large enough to see. Plus there's room for most gauges that a person could want!
Honestly not sure - haven't seen those codes before. Do you have the Ford PID file installed?
