Stacks
Old Aug 11, 2013 | 03:09 PM
DHamSTER's Avatar
DHamSTER
Stacks
Is there anything to worry about, weather wise, with a straight cut or angled cut stack?
Old Aug 11, 2013 | 04:21 PM
joeyd61's Avatar
joeyd61
not if you install at leas 18" of flex pipe under the truck.. straight cut will blow suet on the truck when you start it while raining.I use aussie cut and haven't had that problem
Old Aug 11, 2013 | 04:26 PM
DHamSTER's Avatar
DHamSTER
I cant seem to find a 48" Aussie cut.... What effect does 18" of flex pipe have?
Old Aug 11, 2013 | 04:28 PM
joeyd61's Avatar
joeyd61
The flex pipe has 2 reasons..
1 to let water seep out in a rain while setting
2 it keeps the exhaust from being regid.. It allows the exhaust to flex some
Old Aug 11, 2013 | 04:35 PM
DHamSTER's Avatar
DHamSTER
Alright thank you. Where can I find an Aussie cut?
Old Aug 11, 2013 | 05:10 PM
Tailgate77478's Avatar
Tailgate77478
Don't do it man, just don't do it! You're ruining perfectly good pickup bed space, and a 4" exhaust out the side is plenty.
Old Aug 11, 2013 | 05:12 PM
joeyd61's Avatar
joeyd61
I ended up with Silver Line.
Old Aug 11, 2013 | 05:28 PM
DHamSTER's Avatar
DHamSTER
6ft or 8ft bed?
Old Aug 11, 2013 | 05:29 PM
DHamSTER's Avatar
DHamSTER
you have an excursion, what do you know about bed space?
Old Aug 11, 2013 | 06:01 PM
Tailgate77478
Touche! Don't I know it, every time I need to haul something like a yard of mulch or whatever, I'm outta luck.
Ha...no offense intended to anyone with stacks. When I had a 6' bed truck, I always thought, "Man, even with a 8' bed I wouldn't want to lose any of the space!!!"
Old Aug 11, 2013 | 07:57 PM
DHamSTER's Avatar
DHamSTER
I have an 8 foot bed and 6 square inches isn't a big deal. My plan is eventually to have a tire mount in the bed. I know I lose space but I'm not doing much of anything with my bed. I have a tool box taking up over a foot now. I still managed to bring home 10foot chain link panels with no problem.
I definitely understand what you mean though man. I'm guessing your Excursion has a 7.3. How well does it perform? I have good and bad things on it.
Old Aug 11, 2013 | 09:46 PM
Tailgate77478
Both of them have 7.3L PSD engines, and both perform VERY well. Especially with all of the modifications. "HIS" is currently running stock programming, but with all of the mods you would swear there was a chip in it. The BTS tranny will pull the chassis out from under another truck in a tug-of-war contest. I am exaggerating, of course, but my trucks have cajones.
Old Aug 11, 2013 | 10:10 PM
fordpride's Avatar
fordpride
I had 5" flat tops on my obs and I drilled a 1/8" weep hole in the bottom of the 90's
Old Aug 11, 2013 | 10:12 PM
DHamSTER's Avatar
DHamSTER
How well did a small hole like that work? It's brilliant though!
Old Aug 11, 2013 | 10:17 PM
fordpride's Avatar
fordpride
It worked fine. My truck was white so I'd still get a little soot on it. Nothing major
