Issue with a blinking 4AWD light...
Old Aug 8, 2013 | 03:05 PM
mookiex2's Avatar
mookiex2
Question Issue with a blinking 4AWD light...
Hi all,
I am at a bit of a loss. I have an issue with the 4AWD light flashing on my 1997 Ford Expedition 4.6L. I was pondering the fact that it may be the T case motor, but then I wouldn't have 4L since that is when the motor engages. The following are the facts and I hope someone can help set me into the right direction.
1. I have 2WD, 4H and 4L. No problems there at all.
2. I have replaced the T case Speed sensor and while I was down there I gave it 2 new quarts of Dex.
3. The check engine light is NOT illuminated...
4. I do not have the ABS light illuminated as well.
Best regards and thanks for any helpful advice.
Old Aug 9, 2013 | 04:14 PM
alloro's Avatar
alloro
Which one?
Old Aug 9, 2013 | 05:58 PM
mookiex2's Avatar
mookiex2
I have replaced the one at the rear of the transfer case above the drain and fill plugs. I cannot find the second one that I have seen people mention. Where is that second one?
Originally Posted by alloro
Which one?
Old Aug 10, 2013 | 10:50 AM
alloro's Avatar
alloro
The front sensor is hidden behind the shift motor. You have to remove the shift motor to get to it. Take a look at the PDF I've attached, It show where both the front and rear sensors are.
File Type: pdf
mookiex2
Aug 7, 2013 08:29 PM
pete497
2004 - 2008 F150
Feb 15, 2010 08:11 AM
boeamos
15
Oct 6, 2009 05:20 PM
50BMG
Modular V10 (6.8l)
Jan 19, 2006 09:37 PM
jbdecke1
Nov 29, 2004 09:55 PM
