1966 - 1977 Early Broncos
C4 versus BW1350
Old Aug 8, 2013 | 01:43 PM
Bronjeep's Avatar
Bronjeep
C4 versus BW1350
<hr size="1" style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);">
<!-- / icon and title --> <!-- message -->
Is anybody can tell me if an Bronco 2 with a c4 and a BW1350 transfert case has the same number of spline than a c4 with a Dana 20?
We all know the Ford Dana 20 has a 28 spline input shaft, is BW1350 or 1354 has 28 splines too?
Thanks
Old Aug 16, 2013 | 10:17 AM
Bronjeep's Avatar
Bronjeep
Since I found the answer to my question, I thought I should share the answer.
Bronco 2 : Automatic transmission C4 used on Bronco 2 has 25 splines output shaft, so the transfer case BW1350 or 1354 has 25 splines input shaft.
Early Bronco: C4 output shaft is 28 spline so the Dana 20 has 28 spline input shaft.
Why making it simple when you can make it difficult.
Hope this help.
Old Aug 17, 2013 | 10:18 AM
chrlsful's Avatar
chrlsful
Thanks,
Gunna do some swappin?
What's the vehicle's use?
Bronjeep
1978 - 1996 Big Bronco
Aug 8, 2013 02:00 PM
fenix1
Bronco II
Mar 28, 2013 10:28 AM
