First post! Please help with seats...
Old Aug 7, 2013 | 12:03 AM
monster967's Avatar
monster967
I have tried searching on this site for days to no avail. I'm trying to figure out all of the compatible seats I can get for my 2000 superduty. I only need the front seats. It is a extended cab lariat with fold down armrest in the middle. I heard somewhere that you can lincoln navigator seats that will bolt right in with no mods. Is that true? What other vehicles could I pull seats out of put in mine. Thanks for the help!
Old Aug 7, 2013 | 02:10 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
For sure all Super Duty seats up to 08. Maybe into the newer years as well.
Old Aug 7, 2013 | 08:19 AM
monster967's Avatar
monster967
OK, I didn't know we could go that new on the superduty seats. What about other vehicles that swap over
Old Aug 7, 2013 | 08:30 AM
Supercab's Avatar
Supercab
The Navigator is kinda like an Explorer, kinda like an F150......I kinda doubt that those seats will just bolt into a '99-'07 S/D......may be if you swap tracks??-would be interesting to find out.....
Old Aug 7, 2013 | 12:54 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Footprint is the the same between SD trucks and Excursions. The footprint (think bolts in the floor) for the seats out of an Expedition or Navigator will not be the same.
Old Aug 7, 2013 | 10:09 PM
monster967's Avatar
monster967
I figured half ton seats would not bolt right in. I thought I would come here and ask though just to be sure. Thanks
Old Nov 19, 2022 | 06:26 PM
CorissaMarie333's Avatar
CorissaMarie333
4th Gear
I’m sorry to hijack this post but I figured you might have the info I need
Do you have any knowledge of what the bolt pattern would be for a 1999 Ford E150? I’ve read that they are all compatible after 1997 but I’m not sure what the measurements on mine are. Also wondering if I can switch front and rear seats out?
thanks much
Corissa
Old Nov 19, 2022 | 10:31 PM
T-wood's Avatar
T-wood
Corissa, the e150 econoline van seat sits on a pedestal. The pedestal at least on my 99 e350 and 2001 e350 are the same. Although they are r and left specific. I bought some used seats out of a 97 e450 rv just to have the pedestals and they were also the same. There’s small differences like a drawer under the passenger side but bolt pattern and height are still the same. Rear seats in the van are likely different unless they happen to have the same pedestals.
If your front and rear seats are all 4 captains chairs what you might be able to do is swap the upper part of the seat to the correct pedestal. Only 4 bolts hold the factory seat to the lower pedestal.
Old Nov 19, 2022 | 10:49 PM
CorissaMarie333
4th Gear
Hi T-wood
I am trying to figure out if the rear seats would be compatible with the bolt pattern in a newer van. Even if both patterns are 4 bolt would the actual measurements from bolt to bolt be the same?
I do have all captains seats..good to know I might need new base if I want to swap them out.
I appreciate all your information
Corissa
Old Nov 20, 2022 | 10:31 AM
CorissaMarie333
4th Gear
Originally Posted by CorissaMarie333
Hi T-wood
Corissa
Edit to add: I may be looking to swap the front seats with the rear so I might try the seat swap vs taking the base off. I want the rear seats gone so my dogs have more space. I’m also possibly interested in putting 2 seats in a 1992 Ford box truck. Is the bolt pattern the same on the front seats of E150 van and 1992 box truck?
thanks much
Corissa
Old Nov 20, 2022 | 01:33 PM
T-wood's Avatar
T-wood
I’ll speculate and say there is a good chance your rear captain seats will bolt to the front seat pedestal. For me the easiest way to do this is to remove the four torx+55 bolts that hold the pedestal to the floor. Remove the whole assembly as one. (I do this anytime I need to remove the doghouse). Then attempt the seat swap. There will be a pigtail for your seat belt pretentioner, disconnect that and any pigtails for power seats. I can’t comment on any power seat functions mine were all manual.
Iirc there are 4..1/2” bolts that hold the seat itself to the seat tracks. You have to remove the seat tracks from the pedestal, then remove the seat from the tracks. I can’t remember but during removal of one or the other I had to slide the seat forward or back to access the bolts.
Reinstall seat tracks to new seat. At this point it’s going to be obvious if this works easily or not. Then bolt seat tracks to the pedestal. Install assembly in the van, careful not to pinch wiring under the seat base/pedestal.
Your box truck fittment largely depends if it’s a eseries box truck? If it’s an eseries a quick look at the seat bases/ pedestals should answer that.
Old Nov 20, 2022 | 08:47 PM
CorissaMarie333
4th Gear
Hey T-wood,
Thanks for a thorough and easy to understand answer.
I’ll keep you posted on how the seat exchange goes. It probably will be easier to switch the seats instead of the bases.
Corissa
Harry500
Feb 21, 2022 06:00 PM
landcrazy
Nov 14, 2016 05:02 PM
mrgriz
1983 - 2012 Ranger & B-Series
Sep 28, 2015 08:05 PM
bra$$monkey
Sep 15, 2013 09:10 AM
