Sponsored by: Auxito
Lights Flicker
Old Aug 6, 2013 | 10:31 PM
Austin J.'s Avatar
Austin J.
Lights Flicker
I have a 2000 F-150 5.4. The lights will dim very momentarily and brighten right back up when driving under 2000 rpm. It is barely noticeable except on the small back roads at night. It is actual the most noticeable on the dome light. I replaced a failing alternator probably a month or so ago and I don't remember it before I replaced the alternator. What could be involved with the new part to cause the flicker. Could it be bad ground connection or what? Sorry I don't have any voltage readouts or anything. I can get those tomorrow.
Old Aug 7, 2013 | 08:52 PM
galaxie641's Avatar
galaxie641
Most likely one of those two, I'd start with cleaning both battery connections. Before my Alt. went on my CVPI it did just what you describe. I didn't even get a warning on it, when the alt. went out it went out and I had to think fast to get home on just the battery power. Usually the battery light will come on first, always a chance the replacement alt. is bad. Also check your connection at the alt., may be loose.
Old Aug 7, 2013 | 09:18 PM
Austin J.'s Avatar
Austin J.
Well I'll just go clean all the battery and ground connections when this storm gets done.
Old Aug 8, 2013 | 06:00 AM
projectSHO89's Avatar
projectSHO89
See this thread: https://www.ford-trucks.com/forums/1...ng-lights.html
Old Aug 8, 2013 | 06:51 PM
Austin J.'s Avatar
Austin J.
Very helpful link. I never would have found it because I never thought of it as pulsating but that is a good word to describe it.
Old Mar 7, 2014 | 06:30 PM
Austin J.'s Avatar
Austin J.
Anyone have anymore insight on the cause of the pulsating electricity? It has started to be noticeable in the volume of the radio. Tomorrow I will go out and start poking things with the multimeter to see if I can find where the pulsation is starting from.
cr250
1997 - 2003 F150
Mar 26, 2019 10:00 AM
joe meadows
2004 - 2008 F150
Jun 22, 2015 01:07 PM
Bocomo
2004 - 2008 F150
Nov 5, 2014 08:44 PM
nedshead
1997 - 2003 F150
Feb 2, 2006 07:16 AM
widowmakers20
Jul 10, 2003 04:51 PM
