i need a new one and advance auto has two kinds, one for under 8500lbs gvwr, and for above 8500lbs. my truck is 7300lbs gvwr, what is the differance between them? and can i upgrade to the bigger one?
the main differences is probably- dual piston calipers on the front, and 3" wide drums in the back, whereas the 8500 and under only have single piston calipers and 2.5" drums
on the master, it looks like it holds more brake fluid. the booster probably gives it more mechanical advantage.
all in all, its not going to do you any good unless you upgrade your brakes. it might even cause problems. they do that for a reason in the factory ya know.
On my 82 250 the parts store gave me the wrong one mine was under 85 but they gave me the one for over 85 it bolted up but th ebrkae lines didnt match.
yeah, i know my 84 2wd & 85 4x4 and all kinda different fittings on them.
on the Master cylinder, the rear drum fitting is a 5/16 inverted flare that goes to 3/16 line, the front discs are normal 3/16. the proportional valve, has one 5/16 for the drum input, a 3/16 for the front. the output for the rear is like a huge fitting, like 3/8 or 7/16, and the fronts are normal 3/16. talk about a phreaking pain to find adapters.
Be sure to always try to get the right master cylinder. If it needs adapters, they usually come with it. Otherwise take it back.
The master cylinders can have different bore diameters. This gives different pressures and fluid volumes to the system. Get a master with a smaller bore than the system was designed for, and you will get more braking power, but the pedal will travel farther to the floor. Get one with a bore that is too big, and you get less pedal travel, but less pressure too.
