Sponsored by: Real Truck
2001 f350 A/C Problems
Old Aug 6, 2013 | 08:20 PM
FordFinatic157's Avatar
FordFinatic157
I have a 2001 f350 7.3, and the A/C is cold when you first start it up but after about 15 or 20 miles of driving it will start to gradually get warmer to the point it isn't blowing cold at all, but when i stop and accelerate it cools off again for a few minutes and the cycle starts over. Has anyone ever run into this problem? Any help would be greatly appreciated. Thanks!
Old Aug 6, 2013 | 08:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello FordFinatic157 and welcome to FTE.
You might try this:
Old Aug 6, 2013 | 09:05 PM
rhamm150's Avatar
rhamm150
Kinda sounds like you are losing vacuum to the water valve, or your water shut off valve is not closing completely. If you can try pinching off heater hoses and see if it stays cold, if it does then either valve is faulty or your losing vacuum to valve or entire vacuum controlled componants
newr
Oct 2, 2015 03:00 PM
Rogue_Wulff
1983 - 2012 Ranger & B-Series
Nov 24, 2012 04:28 PM
Rick_Fury
Feb 21, 2011 08:59 PM
cappyd892
Dec 9, 2010 05:00 AM
Big Red
Apr 15, 2004 12:41 AM
