Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2007 alternator replacement
Old Aug 5, 2013 | 08:57 PM
bhlass's Avatar
bhlass
I need to replace my alt. From what I can tell it looks pretty straightforward. 1) Remove top nut holding plastic shield in place. 2)Remove little screw also holding shield (looks like I'll need to jack up the car and pull the splash shield) 3) Remove the 3 bolts holding the alt in place. 4) disconnect the electrical (of course disconnect the batt 1st).
Am I missing anything, any tricks that I need to know about? That little side screw looks a little tricky but I should be able to get it with a ratchet wrench and screw bit. Getting it back in might be a trick due to limited space.
Old Aug 5, 2013 | 09:17 PM
scott91370's Avatar
scott91370
Is it the 6 or 4 cyl?
Never done it on a 4 but the 6 has several more steps. Plan on minimum of 2 hours.
https://www.ford-trucks.com/forums/1...-easy-way.html
https://www.ford-trucks.com/forums/9...r-problem.html
https://www.ford-trucks.com/forums/1...ich-brand.html
simonsi
Oct 16, 2018 05:46 PM
yeksun
17
Sep 1, 2017 12:23 PM
John with beastly 302
Jan 28, 2013 11:01 AM
IndyNova
Aug 27, 2010 07:10 AM
superdutydawg
Mar 11, 2010 01:19 PM
