Dual Intake
Old Aug 5, 2013 | 04:26 PM
DHamSTER's Avatar
DHamSTER
Dual Intake
My Buddy and I designed this intake setup. We were curious to see what you had to say.
[IMG][/IMG]
Old Aug 5, 2013 | 04:30 PM
JOHN2001's Avatar
JOHN2001
It looks good but I'm curious as to why?
Old Aug 5, 2013 | 04:31 PM
DHamSTER's Avatar
DHamSTER
We dont have a real reason as to why we did it but we are testing for higher psi and we have found that spool time is quicker. More air flow really.
Old Aug 5, 2013 | 04:36 PM
JOHN2001's Avatar
JOHN2001
No real reason..... I like it awesome job it looks very good from the picture. I've seen something similar on a different truck before it was the 6637 "stacked" with a spectra filter on a hopped up truck before. I really couldn't think of a real good reason for it.
Old Aug 5, 2013 | 05:23 PM
DHamSTER's Avatar
DHamSTER
Thanks man. We would like to fit dual Riffraff 6637 filters but that would require rotating the battery and removing a lot of the air box around it.
Old Aug 6, 2013 | 11:34 AM
F250_'s Avatar
F250_
From an absolute air flow perspective, dual intake filters are not necessary at all, especially when you're starting out with a 6637.
Two positives DO come from this, though:
1) reduced pressure drop for the incoming air -- the air can get to the turbo easier with less restriction, and
2) your filters will take longer to get dirty -- less frequent require cleaning/replacing.
While increasing filter surface area, though, there is a point where the intake tube itself will be the limiting factor due to friction through the tube. That said, I really don't think you could fit enough air filter surface area under the hood to ever see that happen.
Old Aug 6, 2013 | 03:50 PM
diehardstroker's Avatar
diehardstroker
well im the buddy lol
we did it to both of our trucks, and i believe i saw more of a difference cause im tuned. i def. felt and saw an increase in spool up, no boost gains, but a definite increase in spool. i also saw lower egts (approximately 70*-100*) throughout the whole rpm range, cruising and accelerating.
Old Aug 6, 2013 | 04:22 PM
JOHN2001's Avatar
JOHN2001
Well since you guys are down the road from me I understand the boredom ingenuity good job
Old Aug 12, 2013 | 08:18 AM
DHamSTER's Avatar
DHamSTER
I did end up finding that I had a small psi increase with my foot on the floor.
Diehardstroker is have some slip issues so he hasn't seen an increase in psi yet but we did find performance in other places.
I'm still pretty much bone stock @ 19psi. I reached 20 until it leveled off.
Old Aug 12, 2013 | 08:37 AM
diehardstroker
26 is as high as o can get before she slips....
Old Aug 12, 2013 | 01:24 PM
DHamSTER's Avatar
DHamSTER
What were you getting before man?
Old Aug 12, 2013 | 01:39 PM
diehardstroker
before the tc started slipping i could get 30-31 no problem.
Old Aug 12, 2013 | 01:41 PM
DHamSTER's Avatar
DHamSTER
I didn't realize it was that high!
Old Aug 12, 2013 | 01:44 PM
diehardstroker
that was in hot, tow would get me between 26-27 and economy was about 23-24
Old Aug 12, 2013 | 02:10 PM
DHamSTER's Avatar
DHamSTER
I didn't realize The Beans Chip did all that man!
