Wont start
Old Aug 5, 2013 | 10:50 AM
Siddoway's Avatar
Siddoway
Wont start
Im no mechanic but i try to learn as i go. I have a 2001 f250 7.3L turbo and it has been running great. just this morning i switched out my ac compressor and put everything back together but now it wont start. I checked my cam sensor plug , fuel filter ect.... but when i crank it over there is a clicking sound under my dash? I am at a total loss. any help you be great.
Old Aug 5, 2013 | 06:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
Moving thread to 7.3L Power Stroke engine forum.
Old Aug 5, 2013 | 06:15 PM
carltonwebb's Avatar
carltonwebb
When u were over there changing your compressor, did you knock the small wire off the solenoid on the inside of the right fender? It should be right behind your battery on that side.
Are u saying it turns over but does not fire off or it will not turn over?
Old Aug 6, 2013 | 08:49 AM
01PS's Avatar
01PS
I would guess you did not tighten your batt connections or they are dirty. This has bit me more than once.
Old Aug 6, 2013 | 10:58 AM
Siddoway's Avatar
Siddoway
i put a good charge on my batteries, also i un hooked both batteries to reset everything, then it fired right up!!! Not sure what happened but ill take it. thanks guys
montazch
Jun 8, 2019 08:38 PM
sundancer330
Sep 27, 2014 10:46 AM
mfg02
Modular V10 (6.8l)
17
Jul 28, 2010 04:43 PM
barryhan
May 7, 2009 12:35 PM
