I wonder if it's a speaker?? I did notice a speaker control box by ignition.
What are these two pegs on the hood?
"The original owners daughter would only sell if she could keep her dad's dove hood ornament so I've added a couple piston decorations on the hood to fill the holes that were left."
"the cab / cap intercom not currently operational, I put a battery in the intercom system and got some noises but that's as far as I went."
Reason: Replied to additional question
No, Robert, it isn't........ but it would be nice to have sitting in the driveway. I skimmed thru and read some of the lengthy ad, then quoted to answer your questions.
I think he should have started with an opening bid of 8-9k. Starting as high as he did, I don't think he will have any takers.
That's what I thought, I read his description as well and saw what you posted and figured you copied his words.
Same thing I was thinking. Even starting at $8000, I don't see it going for their asking price though.
I've been looking at that spotlight trying to figure it out.
C7TZ-15313-A .. Spotlight-Left Side (Right Side: C7TZ-15312-A).
This was a dealer installed accessory for 1967/72 F100/350's. FoMoCo bought spotlights from Unity (unityusa.com) who still sells this same spotlight today.
There are two different heads, one type contains a rear view mirror, other type is cone shaped. Both heads were also used on 1957/64 Passenger Cars.
The heads and the handles were the same car/truck, the lengths of the shafts varied, the mounting brackets were specific for whatever vehicles the lights were installed on.
And btw: The outside mirrors on this truck are aftermarket, not genuine Ford.
I know it is unity, but is it a car spotlight? It's gotta have a short shaft because it is mounted to the door.... which is what I don't understand. You point the light at something, then open the door and you've lost it......unless you slide out the passengers side. Haha.
