Rear Suspension problems....need help
Old Aug 3, 2013 | 09:06 PM
20ExSport02's Avatar
20ExSport02
Question Rear Suspension problems....need help
Hey everyone,
I bought an 02 Explorer Sport 2wd back in December of '12. The vehicle actually runs pretty well. The thing I first noticed was the rear suspension seems to slam when going over bumps of almost any size or at any speed. Like if there's a sub-level manhole or something that just the passenger rear tire goes over it makes this terrible slam and sometimes shimmies (Spell check) to the sides like im losing control. I thought I would go ahead and change the shocks, did not make one bit of difference. I have looked up diagrams on the rear sus and everything seems to be there. Any ideas? Heres a picture just to kind of show what I have going on. Thanks!
Old Aug 9, 2013 | 11:16 PM
Mikeman's Avatar
Mikeman
Solid axles aren't known for their smooth ride qualities. My Ranger did the shimmy when hitting bumps in a turn. The only thing I could suggest is to inspect every joint in the suspension for loose bolts and worn/cracked bushings. Push/pull on stuff and check for movement. Of course, you need to find a way to do this safely - not with your Explorer jacked up by the center of the rear axle.
By the way, Ford does not recommend jacking up your Explorer that way.
liljoey112
Dec 30, 2016 08:31 PM
CMOS
May 23, 2012 09:07 PM
csdivine
Offroad & 4x4
Apr 1, 2003 06:53 PM
9explorer8
Oct 17, 2002 12:20 AM
9explorer8
Offroad & 4x4
Oct 8, 2002 11:16 PM
