Oil press sender location
Old 08-01-2013, 09:49 AM
GSlahor's Avatar
GSlahor
GSlahor is offline
Can anyone tell me where the oil pressure sending unit is located on the 6.0 engine....... the one for the factory dash indicator. I don't really think it's a gauge... more likea an idiot light with a pointer ?
Also is the sender a male thread 1/8" NPT ?
I'd like to tee into this location and add an actual oil pressure gauge.
TIA
Old 08-01-2013, 09:58 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
The sender is located in the oil cooler cover just behind the filter houseing, it hs one wire and is a metric thread of some sort almost an acme thread not npt.
Old 08-01-2013, 10:03 AM
GSlahor's Avatar
GSlahor
GSlahor is offline
Pipe or straight ?
Thanks for the info.
So it's a metric thread !
Any idea if it's a tapered pipe thread, or a straight thread sealed with a washer or o-ring ?
I guess I'll need some kind of crazy threaded adapter to tee into that ! !
Any ideas of where to get such a thing ?
Old 08-01-2013, 10:32 AM
dannyboy950
There is a test port on the front bottom of the filter houseing that may be a better place to tee in. Has a 12mm metric thread and most hydraulic shops carry a metric to npt adapter that will fit it. As far as the sender it is a straight thread more like a bolt but different pitch.
Old 08-01-2013, 10:47 AM
GSlahor's Avatar
GSlahor
GSlahor is offline
Good suggestion.
Gary
jcrabb13
08-17-2016 10:44 AM
1990-f250
04-01-2014 10:37 AM
i-w
11-29-2009 09:35 PM
xtrford
1997 - 2003 F150
12-30-2005 06:29 PM
MJEmerson
3.8 & 4.2L V6
18
01-04-2004 09:05 PM
Quick Reply: Oil press sender location
