Seat interchange
Old Jul 31, 2013 | 07:17 PM
SEH43's Avatar
SEH43
Seat interchange
I located a nice seat out of a 92 F150. I'd like to know if this is a direct interchange into my 86 F250
Steve
Old Jul 31, 2013 | 08:30 PM
Gary Lewis's Avatar
Gary Lewis
I am told that it is, but I've not done it. However, I recently asked basically that same question and was told any seat up through 99 would fit.
Old Jul 31, 2013 | 09:07 PM
SEH43's Avatar
SEH43
Thanks Gary, appreciate the quick responce.
Old Jul 31, 2013 | 09:53 PM
Diesel_Brad's Avatar
Diesel_Brad
Steve
It depends on which seat and what cab style we are talking.
It appears you have a super cab. Is the donor truck a super cab? If not then NO.
What seat do your currently have?
What is in the donor?
Old Jul 31, 2013 | 09:57 PM
Gary Lewis's Avatar
Gary Lewis
Brad - Good catch. I didn't see the SC/LB in his sig. My bad.
Old Jul 31, 2013 | 09:58 PM
SEH43's Avatar
SEH43
My bad! I'm not to good w/the acronyms yet. I put SC meaning std cab. Both are for a std cab. I'll fix my signature to make it clear.
Thanks
Old Jul 31, 2013 | 10:11 PM
Gary Lewis's Avatar
Gary Lewis
I was talking about standard cabs, although I hadn't considered other options and should have. Anyway, I think you are good to go. Again, I haven't done it so I'm going on what I've been told, but told by more than one FTE'er.
Old Aug 1, 2013 | 05:18 AM
Diesel_Brad
Thanks
Then YES. since a BENCH seat was the ONLY option
Old Aug 1, 2013 | 11:32 PM
joshofalltrades's Avatar
joshofalltrades
i once put a seat from an early-90s into a late-60s truck, and the only modification needed was to drive out a couple studs to allow the tracks from the truck to bolt onto the donor seat - they changed floor mounting a time or two over the different generations. that said, i don't know if any changes were made in the years in question
Old Aug 2, 2013 | 12:19 PM
SEH43's Avatar
SEH43
Well, I looked at the seat, and it was not as good as the pic showed. So I guess I'm still looking.
Thanks guys for the info, at least I now know what to look for.
Old Aug 2, 2013 | 12:49 PM
Gary Lewis's Avatar
Gary Lewis
Good luck and let us know what you get.
Old Aug 2, 2013 | 02:21 PM
4x484150's Avatar
4x484150
All bench seats are interchangable from 80-96. I'm not sure about other years. If you find a crew cab, the front bench does not fold forward, but the rear one does. I have a rear bench from an 89 crew in my regular cab.
Old Aug 2, 2013 | 03:46 PM
SEH43's Avatar
SEH43
Good to know!
Thanks
Old Aug 3, 2013 | 09:57 AM
RockWVU's Avatar
RockWVU
You know what is rare or hard to find?
A front seat from crew cab.
Yes I know any bench seat will bolt in but the backside is upholstered with vinyl on the seat back. It has a finished look when viewed from backside.
Additionally I have yet to find a cover that covers the entire seatback.
My rear seat is almost mint red vinyl with textured inserts. The front had some rips and sag in the usual spots but the backside looks good.
I am trying to figure out the best way to go here.
I want the two seats to match. Also I don't want to see the cardboard backer if I move the back to the front.
Ideally I would find complete red interior from newer crew cab and sell my current seats.
Did they make red crew cabs in the obs era?
Old Aug 3, 2013 | 10:05 AM
ctubutis's Avatar
ctubutis
I've seen red supercabs (small back seat but two doors) and that should work, too.
Quite honestly, what comes to mind is material (vinyl, felt, whatever looks good) purchased from a fabric store and added to the existing cover.
Removing the existing vinyl will be a lot of work, though, and you'll need a decent sewing machine to sew heavy material like that together. But it can be done, I used to watch my mom reupholster furniture and car seats.
