1978 - 1996 Big Bronco
Washer Reservoir
Old Jun 13, 2003 | 06:29 AM
88bronc's Avatar
88bronc
Washer Reservoir
Anyone know where the third bolt retaining the washer reservoir on an 88 Bronco is? My pump went out, and although it looks easy to fix, I can't find the third bold to take the reservoir out. Thanks.
Old Jun 13, 2003 | 12:41 PM
alanscott's Avatar
alanscott
Washer Reservoir
I don't know if a 88 is the same as a 83, but, on my 83, it lifts straight up to remove. There are 2 slots on the side that the top drops down into.
Old Jun 13, 2003 | 03:37 PM
JBronco's Avatar
JBronco
Washer Reservoir
I don't recall a third bolt on my 90. I think there are only two and then there is a plastic tab that fits into a slot at the bottom, on the fenderwell. Maybe you are thinking that there is a bolt there?
Old Jun 14, 2003 | 02:44 AM
88bronc's Avatar
88bronc
Washer Reservoir
Thanks. I noticed the tab, but the Chiltons said that there was a third bolt and it is definetely hanging up on something. I'll trying pulling on the tab and see if that does it. Just don't want to break the reservoir. Thanks again.
