i have no working gages in my instrument cluster.and the only lights i get when i turn the key is ,airbag and battery light! all fuses have been checked!
only code i get is b1352 ignition key in circuit failure!
I removed my fuse box inside the truck,found the (GEM) and removed it!
Disconnecting all wire's from fuse box and (GEM).
The (GEM) is just a circuit board that plugs into the back of the fuse box its inside a black box to protect it i guess!
Then i put every thing back together,reconnected my batteries and my gages work!
