Sponsored by: Real Truck
VIN info please
Old Jul 27, 2013 | 11:57 PM
Kamstutz's Avatar
Kamstutz
VIN info please
My son is looking at a truck and I would like to verify as much as possible on this truck. VIN is 1FTSW31F92EA11922 I'm out of the country for a while, so I'm trying to get him as much info as possible and he is doing a carfax as well.
Thanks, Kevin
Old Jul 28, 2013 | 01:40 AM
DND58's Avatar
DND58
Here ya go.
VIN Decoder - Ford Truck Enthusiasts Forums
Old Jul 28, 2013 | 07:12 AM
Tom's Avatar
Tom
You can get much more than from a simple VIN decoder. From the site FordEtis home page
* Illustration shows model only
F250/350/450/550 Super Duty, 7.3L Diesel V8 Turbo, True Blue
VIN Number: 1FTSW31F92EA11922
Primary Features
Build Date: 16.07.2001
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Double Cab (3/4 Door)
Version: 350 Series
Engine: 7.3L Diesel V8 Turbo
Transmission: 4 SP Auto 4R100 (Diesel APPLI)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.73
Emission: California Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: True Blue
Minor Features
Medium Flint
Blocker Beam-Underbody Front End
With Tailgate Lock
With 6 3/4' Styleside Steel Box
With Load Box Edge Protectors
156"/3962MM Wheelbase
XLT
Less Special Purpose Vehicle
Less Fleet Related Items
Kentucky Truck Plant Build
U.S. Sales
Security Lock Group
With Camper Pack
9700 LB. GVW
Less Appearance Group
With Cold Weather Group # 1
With Off Road Appearance Pack
With Power Equipment Group
Less Ambient Temp/Speed Pack
With On-Board Diagnostic System
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
With 2 Ton Mechanical Jack
Less Warning Display
Less Fire Extinguisher
Less Tool Kit
With Power Front Windows
With Electric Rear Windows
With Privacy Glass
With Sliding Rear Window
Less Overhead Console
Less Floor Mounted Console
Adjustable Accl/Brake Foot Pedals
With Carpet Floor Covering
Sunvisor - Single Driver W/Strap
With Sunvisor Mirror - Passenger
With Level 3 Door Trim Panel
With Sound Insulation Pack Level 1
Less Exterior Sun Visor
With Bright Front Grille
With Lower Body Moulding
Less Rear Window Protector
Chrome Tube Side Steps W/O Lights
With Dipping Rear View Mirror
Dual Sail Telesc TT Power Mirror
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Seat Belt Warning Light
With 2nd Row Bench Seat - 3 Passngr
With Driver 6 Way Pwr.Seat Adjuster
With Pass 6 Way Power Seat Adjuster
Trailer Tow Prep Pack
With Trailer Towing Attachments
With Front Towing Hook
Exterior Door Handle - Black
With Central Locking System
With Door Entry Remote Control Unit
Less Body Tu-Tone Paint
Less Bodyside Accent Stripe
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
With Inertia Front Seat Belt
With Driver Air Bag
With Passenger Air Bag
Adjustable'D'Ring-Drivers Seat Belt
Less Passenger Air Bag Deactivation
With Frame Mounted Tyre Carrier
With Steel Spare Wheel
With Standard Rear Shock Absorbers
With Single Rear Wheels
7.0 X 16" Forged Aluminium Wheel
LT265/75R-16E A-T BSW Tyre
With Conventional Spare Tyre
Less Wheel Covers
With Bright Wheel Hub Cover
Immersion Heater Engine
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
With Heavy Duty Rear Springs
With Rear Stablizer Bar
3.73
Rear Axle Limited Slip Differential
Ford Axle Type
Rear Axle/Wheel Lube-Mineral Based
With Mono Beam Front Axle
Less Catalyst
With 4 Wheel Disc-Brake
4 Wheel Anti-Lock Braking System
With Standard Transmissn Oil Cooler
Less Transmission Power Take Off
Electric Trans Case And Auto Hubs
With Skid Plates
With Mid-Ship Fuel Tank
With Non Locking Fuel Cap
For Unleaded Fuel
Less Gaseous Prep Pack
With Low Sulfur Diesel Fuel Content
With Steering Damper
With Tilt Steering Wheel
Basic Type Steering Wheel
With Speed Control
With MPH/KMH Speedometer
With Reverse Proximity Sensor
Less Engine Immobiliser
Heavy Duty Battery
Dual Heavy Duty Alternators
AM/FM CD Changer/Clock
Less Radio Pre-Equipment Pack
With NAAO Radio Frequency
Less Daytime Running Lamps
With Front Fog Lamps
Less Roof Marker/Clearance Light
Engine Compartment Light
With Dual Beam Dome Map Light
With Glove Box Illumination
With Load Compartment Lamp
Tail lamps - Level 1
With High Mounted Stop Lamp
With Automatic Headlamp Control
True Blue
F81A-5310-AFD (5200 LB.)
F81A-5310-AFD (5200 LB.) #2
Less B&A Control Codes Issue 030388
4X4 SRW Off Road - Silver/Black
Less LPO 50S Emiss Calib Label
Old Jul 28, 2013 | 10:36 AM
Kamstutz's Avatar
Kamstutz
Tom, Thanks that is what I was looking for. BTW the VIN says Blue paint and the truck is White. Again thanks!
Kevin
CJWisinski
Mar 27, 2019 04:17 PM
Wealthk1
Sep 2, 2016 05:16 PM
Rob89
Jun 10, 2016 08:57 AM
justjake
Nov 29, 2014 11:01 AM
02 Super Duty Guy
Jun 20, 2013 09:40 AM
