Aussie Brianb's truck saga
#91
Glad to hear you solved the coolant leak issue.
The regulator is inside the alternator case, you have to disassemble it to check it. You can do it yourself but you probably only want to if you know that is the cause.
If you can get the alternator load tested it will tell you if you really have a problem.
Here is a good thread on the process of rebuilding the alternator:
How to Rebuild your Alternator - TheDieselGarage.com
#92
Thanks for the link, I'll give it a read.
I checked all the battery connections and the negative on
the second battery was abit loose.
Tightened it up but it did not solve the problem.
Still not certain that the batteries are still healthy, they are
seven years old have have been flattened a few times in the
past.
I will put the load tester on them again later today, or tomorrow,
and see what it has to say.
Does anyone on the list know of any dealers in the Newcastle
area that sell Odessey batteries?
If I have to replace mine I am not going to waste time on cheap
Chinese rubbish.
past.
Chinese rubbish.
#94
#95
Wow that's cheap , i just fitted a pair of Supercheap 850 cca batteries they have a three year warranty $230 ea. time will tell though
#96
The saga continues
It's time to deal with an oil leak at the rear of the engine.
I suspect its from somewhere around the turbo pedestal,
there are a few possibilities.
Because the turbo has to come off then I am going to do
everything I can back there so I don't have to do the same
job again.
I am replacing the pedestal and turbo outlet with a non-EBPV ones.
While the turbo is off the waste gate actuator is being replaced
with a "Turbomaster" mechanical controller
http://http://www.dieselsite.com/199...ontroller.aspx
and the boost relief valve.
http://www.dieselsite.com/boostreliefvalve.aspx
Decided to fit a WWII as well while the turbo was off.
http://www.dieselsite.com/ww2_gtp38.aspx
While I am in there the up-pipes are being replaced with the
IH style pipes.
I am also doing the big plugs on the rear of the HP oil rails,
as they can also develop a leak.
The ICP sensor and ICP regulator are also being replaced,
as well as the HPOP lines.
I am using the CNC lines as they eliminate the leak prone
quick release fittings.
CNC FABRICATION 7.3L SD COMPLETE REPLACEMENT HPOP AND HPX LINE KIT
The downpipe needs replacing as well as there appears to
be a crack right at the top near the turbo outlet.
I bought one of the "Diamond Eye" pipes and have added a
flex joint to it to try to prevent the crack from happening again.
New downpipe ready to be welded.
Unrelated to all the other jobs, the bushes on the sway bar arms are
totally trashed so the arms are getting replaced with geasable
"Moog "ones.
As you can see from the photo, a lot of parts to play with.
Wish me luck.
I have done the easy bit, spent the money, next the hard part, doing the job.
job again.
IH style pipes.
"Moog "ones.
Wish me luck.
#97
#98
Same Same, the only thing i can think of doing so you don't keep getting a CEL is a 470 ohm 1/2 watt resistor on the W/G harness.
When you fit the TM you will get rid of the red and green line, you can block them off or get rid of them all together and fit a resistor to stop the CEL.
You'll need to block off the low pressure out let (red line) on the lower end of the intake spider with a rubber cap or take it out all together and plug it ( drill and tap) , i'll post some photos.
This is what i did, see where the screw driver is pointing, that's the rubber plug you need , that's where the red line elbow was.
That's the W/G solenoid harness that i fitted the 470 ohm 1/2 watt resistor to..
Here's the two ends (W/G harness and resister capped)
I think the flex pipe is a good move mate i wished i'd thought of that when i fitted my exhaust.
Good luck with the conversion mate.
Oh , make sure you use viton O-rings on the pedestal Ford 7.3 Diesel Turbo Pedestal O-rings - Set of 4, so you don't have any leaks in the immediate future.
Plenum inserts are also a good idea while your're on top of the motor.
RDP Plenum Reinforcing Inserts? - Ford 7.3L 99.5-03
#99
Blue,
Manythanks for the info and photos.
I knew I was going to have to deal with the waste gate vacume
lines and wireing and so your info is of great help.
As for setting the boost pressure with the TM, do you have
any recommendations?
From what I have read it seems that 26psi is about as high
as I should push a stock engine.
I still have standard injectors and HPOP and am unlikely to
change these in the forseeable future due to "budgetry constraints".
I have already done the plenum inserts, did them when I fitted
the Afe manifold and replaced all the boots.
I have bought all the required seals and "O" rings for the job
from "DieselOrings". The new pedestal came with a set but I
have no idea what they are made of, so thats why I opted to
get good viton ones.
No point skimping on these relatively cheap parts on this job.
I removed and cleaned the exhaust back pressure sensor and the
pipe the other day. It was not all that dirty but I did get a bit of
carbon flushed out of the pipe.
Is there any way to test the sensor to make certain it is
functioning correctly?
#100
I wouldn't over 26 psi with a stock 38 even though you will be fitting a WW2, i have mine set at 30 psi (38R).
#101
Thanks again.
#103
I was really just curious what symptoms would a failure of the
sensor exhibit that's all.
Are you saying that the sensor failure would result in increased
fuel consumption?
#104
#105
Between a failed sensor and a blocked tube it will IMO, and you'll have loss of power and your boost will fluctuate some, as the PCM will get the wrong readings to open the EBPV.
if you have have gutted your EBPV you could probably get a pig tail to eliminate the sensor altogether.
In all the research I have done on eliminating the EBPV I have not
come across anything about eliminating the sensor.
I expect it would be a case of replacing the tube with a plug to
seal the exhaust and fitting a resistor in place of the sensor.
No clue as to the value of the resistor though.
Have you any idea where I might find what resistance the
computer expects to see from the sensor?
Would measuring the resistance of the sensor with my
multimeter give me the correct value?
