Ac venting problem
Old Jul 27, 2013 | 07:30 PM
Archuriel's Avatar
Archuriel
Ac venting problem
My ac vent gets stuck somewhere and when it is stuck it barely blows air out. Then all of a sudden a small click noise and it opens up more and then blows sufficient air. Can someone point me in the right direction to fix this. Thanks
Old Jul 27, 2013 | 07:33 PM
norfolknova's Avatar
norfolknova
Hard plastic Vacuum lines under the hood, the vents are controlled by vacuum.
Matt
Old Jul 27, 2013 | 07:44 PM
Archuriel's Avatar
Archuriel
Matt
Thanks for the quick reply.
Old Jul 28, 2013 | 08:31 AM
tjc transport's Avatar
tjc transport
i ain't rite
also, you may have crap in the ducts blocking the blend doors from opening properly.
Old Jul 28, 2013 | 03:28 PM
Archuriel's Avatar
Archuriel
I read this and this seems to be a common problem The Last Resort Ford Blend Door Fix.
However the culprit was a hole in the vacuum line going to the actuator. I will however check the blend door also.
leogla
Sep 5, 2013 10:12 PM
CraigK
24
Aug 8, 2010 07:43 PM
crazie0025
Oct 19, 2006 11:12 PM
bcjim
1983 - 2012 Ranger & B-Series
Apr 21, 2005 11:29 AM
swenson
1978 - 1996 Big Bronco
Jul 31, 2002 02:12 PM
