Ok my truck just reciently dripping a brownish fluid, not sure if its oil or the steering fluid, im thinking steering fluid, but I know the oil has leaked before so I figure its time to replace the oil pan anyways, and it also has lots of JB wield on it so I think its been patched once or twice and im just not comfortable driving long danstances anymore with it devloping these two issues, so I will be asking a two pronged series of questions to try and resolve both at the same time if able...
OIL:
whats the part number/pan type I need, im going to try for OEM but I may need to aquire it from NAPA, not sure if they will have same or different numbers.
do I need to get new bolts/studs?
will I need to do studs or will bolts be ok??
whats the part number for the gasket? I want to try and buy new OEM if able.
