HELP PLEASE!!!!!!
Old Jul 24, 2013 | 07:54 PM
roadhouse1979's Avatar
roadhouse1979
Exclamation HELP PLEASE!!!!!!
thanks in advance!! i have a 1996 5.0L f-150.
found a 96 explorer with hopefully gt 40 heads for my f-150, do i need more then the heads from the explorer like the intakes?
also these are my mods i wish to do also want to confirm before i start my process aswell as any other suggestions you have:
1) GT 40 heads ( 96 explorer or 93 cobra)
2) stock air system with K&N filter
3)morcraft spark plugs
4) 9mm ford racing spark plugs
5) msd coil & distribuator Cap $ rotor
* comp cam forget what ser#
* Headers would like suggestions??( will be running duals)
* Also you mentioned gears what would you suggest
Old Jul 24, 2013 | 08:00 PM
88LX5.0H's Avatar
88LX5.0H
Use your truck intake. The Explorer intake is more for midrange up upper RPM power. It makes a damn good Mustang intake. Your factory truck intake is way better simply because it was designed for a full sized truck. FYI Explorer valve springs suck. They're junk. You will need different springs for anything other than the stock cam. Unless of course you like to float valves
Bulldawg1081
Jan 10, 2017 07:53 PM
drake_bartel
1978 - 1996 Big Bronco
Jan 30, 2015 10:35 PM
roadhouse1979
Jul 28, 2013 10:19 AM
ckcn10
126
Mar 2, 2007 12:20 AM
Shinoda
Jan 1, 2004 12:34 AM
