HELP WITH PCM CONNECTION
Old Jul 24, 2013 | 05:42 PM
f2504x4man's Avatar
f2504x4man
Hey sorry to start a new thread. Its been a long time without a response on my old thread. I still can't find any wire diagrams for the pcm to diagnostic link connector. I've tried a solus pro, vag can obd2 scanner , and now ae. No communication with pcm. I have power. The scanner powers on. I've searched and searched for a wire diagram or troubleshoot info for weeks now and still have found nothing. Dealership said my truck is obd2. Not sure where else to go here. I'm getting 5-7 lbs of boost max instantly under 1/2 throttle (which I thought was a little quick for these trucks). Fuel pressure is 80 psi idle with the regulator shim. A couple pinhole leaks in the welds on the downpipe. Truck seems like its missing a cylinder before it fully warms up than its fine. Hunting back and forth at shift points in between gears. Seems like it would be a lot easier to diag if I could communicate with the pcm. 96 F250 7.3 auto trans. Any help would be greatly appreciated. Oh and no check engine light on but comes on for a split second when I turn the key forward.
Old Jul 24, 2013 | 05:44 PM
f2504x4man's Avatar
f2504x4man
Oh and only getting 13 mpg babying the throttle without boosting the truck at all. 4.10 gears
Old Jul 24, 2013 | 06:16 PM
fordpride's Avatar
fordpride
This is a SD but it should be the same
https://www.ford-trucks.com/forums/1...connector.html
Old Jul 24, 2013 | 07:03 PM
f2504x4man's Avatar
f2504x4man
Sweet thanks. Ill check mine and get right back.
Old Jul 24, 2013 | 07:23 PM
f2504x4man's Avatar
f2504x4man
Everything checks out but there is no pin 7 ISO Bus. Also pin 13 module programming signal is grounded key on or key off. Is that the problem? I'm guessing im not suppose to have a pin 7?
Old Jul 24, 2013 | 08:02 PM
f2504x4man's Avatar
f2504x4man
Ok i believe i traced the wire to the pcm. should be on the top row right next to the hold down bolt to pcm. purple wire. connected to pcm it can pull 12v useing the purple wire as ground. if i disconnect the harness from pcm i get 6 volts using same 12v source and grounding the purple wire. anyone have a pcm connector diagram to confirm this is the same purple wire before i go cuting and splicing? My question is where does the purple pin 13 (module programming signal) wire from the diagnostic connector go? Strait to the pcm?
Old Jul 24, 2013 | 08:33 PM
fordpride's Avatar
fordpride
Old Jul 24, 2013 | 09:03 PM
stainlessstroker95's Avatar
stainlessstroker95
Is the fuse for the power point outlet blown?
Old Jul 24, 2013 | 09:28 PM
f2504x4man's Avatar
f2504x4man
Spliced in a new wire. Pin 13 gets no connection when the pcm is disconnected but is grounded now with the pcm connected. If the first diagram is correct it looks like something is wrong with the pcm. Still no communication. I don't think its causing any drivability issues so I'll leave it until I can afford a new pcm. Thanks fordpride. I really appreciate the help. Any other input on the subject is welcome.
Old Jul 24, 2013 | 09:35 PM
f2504x4man's Avatar
f2504x4man
Also pin 13 does not ohm out to ground like its not connected to ground(like it should). But if I connect pin 13 to the negative probe on my multimeter and 12v+batt to the positive red probe thats when I see 12 volts on the meter. I believe that means pin 13 has ground and thats where my problem is. If i'm missing something or doing something wrong please let me know.
Old Jul 27, 2013 | 04:38 PM
f2504x4man's Avatar
f2504x4man
Fuse is good. Still no communication. Check engine light finally came on when I pulled the icp conector so everything seems to work but communication with pcm.
Old Jul 28, 2013 | 09:33 AM
Midwest Dually's Avatar
Midwest Dually
I may be way off base, but what scanner are you using? Have you tried an alternative one at a different parts house, just to rule out a bad scanner?
Old Jul 28, 2013 | 12:40 PM
f2504x4man's Avatar
f2504x4man
My ae is not working on any car. Im using a parallel port to obd2 connector on my pc and not the usb connector im suppose to use. But the solus pro will not communicate but gets power and my vag can obd2 scanner connects but reads no data, check engine light on with no codes and gets an error when I try to clear codes. I also tried a scan gauge 2 which also wouldn't communicate.
Old Jul 28, 2013 | 03:48 PM
nomad221's Avatar
nomad221
You're going to need a usb port or serial AE proline device. From the name, the proline device sounds like a serial adapter of some sort, IDK. The only way I can run diags and read codes with my AE, I changed the communications configuration to NON OBD2 only and the interface type to J1850 PWM.
billyboie
Mar 22, 2025 05:42 PM
flatbedpower
Nov 11, 2013 05:05 PM
f2504x4man
Jul 17, 2013 04:00 PM
Ryan Weaver
20
Jan 18, 2013 10:48 PM
RoyLayman
1997 - 2003 F150
Aug 26, 2004 11:04 PM
