95 7.3 shut off like a switch, wont restart
Old 06-16-2013, 07:04 PM
acf6's Avatar
acf6
acf6 is offline
We were headed to a truck meet friday night when one of my buddies in the convoy with his 95 F350 7.3 just died pulling upto a red light like he hit a switch, no stumbling/surging/nothing. Cranks, but doesnt restart. That night we tried diagnosing it with like 10 guys but we had no luck, had to tow it home. We unplugged the ICP sensor then as well, and it was actually melted, but still wont restart.
I dont know much history of the truck but it has 273k miles and he installed new injectors a few hundred miles ago. Weve had it hooked up to either my truck or my buddies cummins charging it while trying to start it.
-We triple checked every fuse under the dash, and the hood.
-Horn worked, so we swapped that relay with the IDM and PCM relays and those were both good.
-Tested GPR, working.
-No smoke coming out exhaust
-Wait to start light comes on and takes probably 15 seconds to go off.
-Tach does not move when cranking
-Fuel bowl is filling up
-Cleared all the codes, and the only one left is P1280
-Hooked my scangauge up to it and read ICP, while cranking first try was 0, second was 2400, third was 0....
-Switched from front to rear fuel tank, still nothing...
-UVCH were both plugged in
Hes short on money because hes a senior in high school and bought this truck from a farmer for like $2000, and has been putting a bunch of money into it fixing necessary items. Swapped the CPS today, no change. Theyre going to replace the ICP sensor tomorrow after work. The only 7.3 around is a super duty so we dont want to pull the fender off just to see if we can swap IDMs and determine if thats it. Any ideas? No idea what they did when the injectors went in, if that could be affecting something
Old 06-16-2013, 07:13 PM
fordpride's Avatar
fordpride
fordpride is offline
With no tac movement I'd start looking at the CPS wiring
Old 06-16-2013, 07:15 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
I would start with a new cps from ford, sounds like you need a new icp sensor also. The idm from a 7.3 super duty will work on his too, no need to pull the fender off to get to it either. It just unbolts from the fender and its free.
Old 06-16-2013, 07:18 PM
acf6's Avatar
acf6
acf6 is offline
Thanks guys, he said the CPS was only like $16 so it probably was from napa. I know the IDM on the OBS is on the inside, but on the super duty isnt it behind the fender?
Old 06-16-2013, 07:20 PM
fordpride's Avatar
fordpride
I'd try a fird or IH CPS. The ones from parts stores are known to be dead out the box
Old 06-16-2013, 07:21 PM
fordpride's Avatar
fordpride
To get to the sd idm you have to remove the inner fender
Old 06-17-2013, 06:15 PM
acf6's Avatar
acf6
acf6 is offline
Alright, we put in a Ford CPS and ICP sensor. ICP sensor wiring looks good. Still nothing. Whats next...swap IDMs? IPR?
Old 06-17-2013, 07:23 PM
fordpride's Avatar
fordpride
Are get it put on a AE
To start a psd you need
10.5 v
125 RPM
500psi HPO
15psi fuel pressure
Old 07-25-2013, 05:06 PM
jcass29's Avatar
jcass29
jcass29 is offline
I don't mean to hi jack your thread but I have a 96 f250 7.3 turbo. It has shut off on me a hand full of times just like you turn the ignition off no stumbling, surging, or anything but it has always started right back up. Recently it shut off on me and it took a good minute to start back up. Today coming home it shut off while driving and would not restart I ran the battery's down and had to have a jump. once I got the jump it fired right up and I drove it home, now I'm scratching my head. Any help would be appreciated.
Old 07-25-2013, 05:07 PM
acf6's Avatar
acf6
acf6 is offline
With this truck it happened to be the HPOP went bad
Old 07-25-2013, 05:10 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Get a CPS (cam position sensor) from IH or Ford. Stay away from the parts store ones. The sensor is just above and to the left of the crankshaft pulley on the front of the engine. It's easier to get at from below. Takes a 10mm wrench and about 5 minutes to change.
Old 07-25-2013, 06:05 PM
jcass29's Avatar
jcass29
jcass29 is offline
Yep, I just had the codes read and I got CPS code and Low volts code which I attribute to running the battery's low trying to start it. Thanks
Old 07-25-2013, 07:31 PM
fordpride's Avatar
fordpride
Yup get a CPS.
That code really doesn't mean anything. These trucks will set a CPS code with extended cranking
Old 07-25-2013, 08:18 PM
pilgrimbizket's Avatar
pilgrimbizket
pilgrimbizket is offline
How did you find that out
7.3Gtp38r
1999 to 2016 Super Duty
05-11-2019 09:41 PM
Natdog
13
04-30-2019 01:19 PM
1996_powerstroke
02-19-2016 10:05 PM
chrisvan09
08-01-2011 12:48 PM
daggerNC
11-13-2008 02:50 AM
Quick Reply: 95 7.3 shut off like a switch, wont restart
