351W head question
Old Jun 12, 2003 | 05:23 PM
mmarmino's Avatar
mmarmino
Question 351W head question
My 1985 F-150 with a 351W recently ran hot and cracked a head. I have found a used head to replace it but there is one difference. On mine the rocker arms are bolted down, so there is a threaded hole. But on the other head there are studs sticking up to attach the arms to. My question is, are the studs pressed or drilled into the other head? Thanks for any help.
Old Jun 13, 2003 | 01:00 AM
baddad457's Avatar
baddad457
351W head question
most likely the studs are pressed. you really need to find a matching casting #'s head if you just want to change only one. Otherwise, one side of the motor will have either more or less compression than the other. And the pushrods won't be the right length for one side either
Old Jun 13, 2003 | 04:30 PM
mmarmino's Avatar
mmarmino
351W head question
which numbers are the cast numbers?
Old Jun 13, 2003 | 06:23 PM
baddad457's Avatar
baddad457
351W head question
The casting #'s are located under the intake ports. Yours are probably something like E5AE, E5TE or something similar.
Old Jun 14, 2003 | 09:59 AM
mmarmino's Avatar
mmarmino
351W head question
thanks for the help
Old Jun 14, 2003 | 08:55 PM
baddad457's Avatar
baddad457
351W head question
anytime
