Engine Swap 89 F150
Old Jun 12, 2003 | 01:56 PM
nbr1chinchilla's Avatar
nbr1chinchilla
Question Engine Swap 89 F150
I want to put a rebuilt 351W from a 72 Galaxy 500 into my 89 F150. Can I put the EFI from my 89 onto this motor?
Old Jun 13, 2003 | 09:56 PM
steve83's Avatar
steve83
Engine Swap 89 F150
It should bolt up, except the knock sensor, which isn't important. (A Ford engineer told me it's not reliable anyway.) You'll need a block-off plate for the fuel pump. You'll probably have the least trouble if you only use the short block.
Old Jun 15, 2003 | 12:19 AM
ludis's Avatar
ludis
Engine Swap 89 F150
What's in the F150 now? If it is a 5.0, then you'll need (at minimum) the lower intake manifold and the distributor from a 5.8 EFI truck.
Old Jun 15, 2003 | 12:23 PM
gamehunter's Avatar
gamehunter
Engine Swap 89 F150
A 5.8 EFI lower will NOT bolt up to a 5.0 upper intake. The 5.8 has oval ports, the 5.0 has rectangular shaped. But it should work if you have a 5.8 in your F-150 right now and plan on using everything from the long block up. Although im not 100%, I think that the heads would be OK to use because from what I know the 5.8 doesn't have an in head A.I.R. system anyway, it goes straight to the exhaust manifolds.
1989bricknose
May 12, 2016 06:38 PM
Marteney
Jan 5, 2014 01:33 PM
Hunt89
Jan 1, 2010 05:22 PM
89f15o
Jul 10, 2009 11:35 AM
