9 inch rear
Old Jul 20, 2013 | 10:24 PM
0ldman's Avatar
0ldman
9 inch rear
My F100 had the rear changed before I got it, dude snapped axles, changed the gear for mileage.
The only info I've got from him was it was "3300s, the biggest gear Ford ever made."
I figured I could put a tach on it, check the RPM vs the speed but I'm almost certain the speedo gear is wrong as well. I'd have to get someone to pace me.
Any tricks to identifying the rear gear?
Old Jul 20, 2013 | 10:46 PM
85e150's Avatar
85e150
3300s....never heard of it.
Jack up and support both rear wheels. Chock the fronts etc. so you don't roll over yourself. Put the trans in neutral, and turn the drive shaft, counting the turns of the shaft vs. one turn of the wheels--both turning at the same speed. You might need a couple helpers to turn the wheels while you watch the shaft--probably a better way to do it.
You can check MPH vs. RPM, but only if you have a known good speedo.
You can drop the carrier and count the ring and pinion, but that's a bit messy.
Old Jul 20, 2013 | 11:43 PM
0ldman's Avatar
0ldman
I've never heard of them myself. Long time gear head, but new to old Ford trucks.
I might go with the follower and tach, but I don't have a tag yet.
How many teeth on the ring and pinion? Not liking forward to the smell of gear oil, but it may be quicker than getting someone to follow.
Old Jul 21, 2013 | 01:14 AM
Fordboy88's Avatar
Fordboy88
do you have or know anyone with a gps? that way it takes out all the variables with your speed. never heard of "3300's" either
Old Jul 21, 2013 | 01:36 AM
0ldman's Avatar
0ldman
I thought about that a little while ago.
I'll borrow my dad's and take it for a drive.
I've got to pull my tach from my Comet, probably just rig it for a quick run.
I need to get the tag and get it legal. I've had the truck for a year and a half and just decided I'm going to keep it as is for now.
As though I need another project.
Shadowrider123
19
Jan 20, 2015 05:56 PM
Textile302
Nov 3, 2014 03:22 PM
GaryLP
Jun 20, 2013 09:58 PM
jaye
Dec 31, 2005 08:43 AM
scoobzter
Oct 28, 2004 12:39 PM
