Dana 44 help required
Old Jun 12, 2003 | 01:13 PM
51dueller's Avatar
51dueller
With the Dana 44 rear axles. You can like use gears to 3.73 and then it goes 3.92 - 4.56. It it the case or the ring carrier that limits the gear ratios used? I want to put a higher gear ratio than my 4.27:1.
Old Jun 12, 2003 | 05:05 PM
millertime300's Avatar
millertime300
The carrier limits it. The ring from a say 4.27 would be too big to bolt to a small carrier. The case is fine.
Old Jun 12, 2003 | 05:15 PM
51dueller's Avatar
51dueller
Thanks
