Weird A/C problem...
Old Jul 24, 2013 | 11:48 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by Technologiq
Ramsay - are you sure there is no air coming out of the defroster? You say you hear but don't feel it. I only ask because I ran into this yesterday and after reading posts on here I'm 99% sure it's the vacuum leak problem.
Does your truck have the automatic temp controls or is it the *****?
Please re-read post # 8. The circuitry for the refrigerant control is the same regardless.
a lot of vehicles have the thermo sensor in a location that allows the evaporator to over cool,
I happened to go back and look closer to the 05 Excursion's A/C control circuitry. It does not have an additional "De-Icing" switch mounted in the evaporator housing that is supposed to open up in the event the evaporator gets too cold shutting off the compressor.
Old Jul 24, 2013 | 09:40 PM
Bananarama's Avatar
Bananarama
The vac check valve is in the reservoir which is a black rectangular box/Tupperware thing near the battery on the 6.8... If your driving and get on it or go up a hill and the ad stops coming out of the front vents and changes to the defroster it's because your losing vac. When stepping on the gas you lose vac. That's the point of the reservoir and check valve.
Old Jul 25, 2013 | 07:29 AM
projectSHO89
The OP's information has made it pretty clear that this is not a vacuum problem.
Old Jul 25, 2013 | 07:51 PM
Bananarama's Avatar
Bananarama
Yes I know, but in a post someone said there's isn't a check valve and that assumption is wrong. But thanks for pointing out 3rd grade reading.. And as a shop owner, it's imperative to know where components are to properly diagnose, but what the heck do I know- I'm not an expert and rely on this forum for help time to time but knowledge is power.
Im Spuds
Jul 8, 2015 08:29 PM
Andy's Beast
Aug 25, 2013 10:16 PM
JaceF8
1997 - 2003 F150
Aug 25, 2009 09:49 PM
Davis & Sons
Apr 23, 2009 09:06 PM
200000+F150
Jul 15, 2004 02:51 PM
