1978 - 1996 Big Bronco
gearing help 1987 bronco
Old Jul 19, 2013 | 03:19 AM
Matthew521's Avatar
Matthew521
I Have A 1987 Bronco With A 5.0, 12" Lift, And 38" Tires. Im Assuming It Has Stock Gearing Because It Is So Gutless And I Mean GUTLESS, Every Thing Under The Hood Is Stock Any Gearing Suggestions? Also I Have Never Ownd A 5.0, Any Must Haves To Gain A Bit Of Power? I Hear These Motors Have Great Potential Any Help Would Be Much appreciated Thank You! And Sorry For Every Word Begging With A Cap My Phone Dose This On Every Forum.
Old Jul 19, 2013 | 08:41 AM
Conanski's Avatar
Conanski
Is that truck carbed or EFI? There is a ton of potential in there but it will take a cam change and a full exhaust system with headers to see any of it, if you retain EFI get a Crane 444232 cam and lifter set but if it's been converted to carb the Comp 35-234-3 is a better choice.
The ideal stock gearing for a 5.0 truck with stock sized tires is 3.73 to 4.10 so with 38's you should be looking at 5.30's for sure.
P.S. The axle code on the drivers door pillar will tell you what the stock gear ratio is... https://www.ford-trucks.com/article/...de_Chart_.html
Old Jul 19, 2013 | 11:37 AM
Matthew521's Avatar
Matthew521
oh Wow Really I Was Thinking About Getting 4:10'S And I Was Thinking That Might Has Been To Low, And It Is EFI and Also How Is The Reliability These Engines.
Old Jul 19, 2013 | 07:00 PM
Conanski's Avatar
Conanski
No.. not even close. Uncorked this motor makes a ton more power but it's all above 2500rpm which is about where your stock motor peaks right now, so you need a LOT more gearing to work with that kind of powerband.
Very good.. a well maintained engine should have no problem going 2-300 thousand miles.
1963f100
Jan 6, 2018 08:37 AM
JohnsonA
Apr 20, 2016 09:11 PM
flatdeck 82
Nov 26, 2009 11:02 PM
voelker0319
Oct 5, 2008 09:12 AM
Malone Loner
Nov 1, 2003 10:42 AM
