Sponsored by: Real Truck
Hub assembly
Old Jul 18, 2013 | 05:29 AM
JPs250's Avatar
JPs250
Hub assembly
Replaced drivers side front hub bearing assem. now caliper bracket presses against rotor and wont allow to turn. Whats the cheapest fix?
Old Jul 18, 2013 | 06:10 AM
senix's Avatar
senix
sounds like the rotor is not completely seated on the hub.
Old Jul 18, 2013 | 08:38 AM
Kdr358's Avatar
Kdr358
Did you install the bracket correctly? It sounds like the rotor is not seated as stated above.
Old Jul 18, 2013 | 10:59 AM
EXv10's Avatar
EXv10
Something is not in there right.
Old Jul 18, 2013 | 11:08 AM
JPs250's Avatar
JPs250
The bearing and hub is all together in an assembly. I checked fit with rotor by puting lug nuts (2, 180* off) hand tight holding rotor on. Then when I put bracket on it contacts the outside edge of rotor.
Old Jul 18, 2013 | 11:18 AM
senix's Avatar
senix
take the rotor off and flip it.
Put the tire on and those two bolts opposite of each other and tighten them down a bit to ensure the rotor is all the way on the hub.
Potentially you have a wrong part? Where did you get these parts at?
Old Jul 18, 2013 | 05:02 PM
JPs250's Avatar
JPs250
Apparently there is two diff thicknesses for the wheel stud flange. Now next question will a 4 wheel abs hub fit on a 2 wheel abs truck and just cut the sensor wire?
quisp
Aug 7, 2010 05:15 PM
cotote
Dec 7, 2008 06:23 PM
ExpySport
Apr 6, 2008 08:25 AM
DJack
1978 - 1996 Big Bronco
Jan 11, 2004 07:57 PM
Monsta
Feb 3, 2002 09:38 AM
