Smelly AC
Old Jun 12, 2003 | 10:15 AM
Fordcr's Avatar
Fordcr
Angry Smelly AC
When my 2000 Expy XLT is on Max AC it starts to stink.
Any ideas?
Thanks
Chris
Old Jun 12, 2003 | 06:18 PM
elwhoppo's Avatar
elwhoppo
Smelly AC
Leaking Heater Core!!
Old Jun 12, 2003 | 07:11 PM
Ultramagdan's Avatar
Ultramagdan
Smelly AC
I assume you are not talking about a antifreeze smell?
I would check your drain from the evaporator to make sure it is not plugged. Sounds like you have a colony of mold on it and those can be a pain to irradicate. It stinks because you are not drawing fresh air in when you select max AC. It only recirculates air inside the cabin.
Old Jun 12, 2003 | 07:44 PM
Fordcr's Avatar
Fordcr
Smelly AC
I believe it is mold, I know there is a drain but didn't find it yet, Any ideas where exactly it is?
Old Jun 13, 2003 | 09:24 PM
Ultramagdan
Smelly AC
It should be on the right side of the vehicle about where the firewall is. When you run it awhile it should be leaving a puddle of water underneath the vehicle - even after you shut it down. If you don't have a puddle or any sign of water then it is plugged.
Old Jun 14, 2003 | 01:33 PM
steve83's Avatar
steve83
Smelly AC
Does that thing have an A/C air filter somewhere in the dash?
Old Jun 14, 2003 | 03:01 PM
Fordcr's Avatar
Fordcr
Smelly AC
not that I can find
Old Jun 18, 2003 | 04:05 AM
fordin K's Avatar
fordin K
Smelly AC
yep probably mold. find the tube on the firewall side, look inside
at the same general area. disconnect tube and try using something to blow out or push out with. or vacuum to suck
up. you might have to clean the evaporator fins of the carpet
off too, or else anytime you hit recirc. you have a wake up call.
