Smelly AC 2000XLT
Old Jun 12, 2003 | 09:38 AM
Fordcr's Avatar
Fordcr
Angry Smelly AC 2000XLT
My truck has the smelly AC syndrome. What seems to be the best cure?
Thanks
Chris
Old Jun 12, 2003 | 11:56 PM
Luzer27's Avatar
Luzer27
Smelly AC 2000XLT
To my understanding this comes from a fungus living and groving on the evaporator (the unit which air passes through into the cabin) Ford has a TSB for this and there is a liquid that gets poured behine the squirll cage to fix this. I am not sure what the fluid is or any substitutes.
Old Jun 13, 2003 | 05:49 AM
BigMattXXL's Avatar
BigMattXXL
Smelly AC 2000XLT
Ford has some sort of fumigator "termite tent" for getting stinky fungus/bacteria out of cars. Call your dealer. I think it's about $50.
Take care!
XXL
Old Jun 13, 2003 | 09:27 AM
luxury's Avatar
luxury
Smelly AC 2000XLT
One way to avoid this problem in the future is to not leave the airflow selector in the OFF or MAX AC positions when you turn the truck off. In the OFF and MAX AC positions the damper for outside air is closed so the condensation has nowhere to go. In all other positions the outside air damper is open and the condesation can evaporate before the fungus can set in. I've been doing this since I first read about AC stink problems and my truck still smells fresh as a daisy (except when the kids leave banana peels under the seat ).
Old Jun 16, 2003 | 07:39 PM
Luzer27's Avatar
Luzer27
Smelly AC 2000XLT
Isn't the damper door Vaccume actuated so when the truck is off it will always return to the same position?
Old Jun 17, 2003 | 07:35 AM
luxury's Avatar
luxury
Smelly AC 2000XLT
I believe it is vacuum actuated; however I think it stays in the same position when you turn the truck off. Of course, you need to place the switch in the right position before you shut the engine off, or else the vacuum is gone and the damper will not move. The owners manual actually has the information I posted earlier about not leaving the switch in the OFF or MAX AC positions with the truck off.
Bford1022
1997 - 2003 F150
17
Feb 8, 2020 10:03 AM
96f150
1997 - 2003 F150
Apr 10, 2015 08:42 PM
Bford1022
Modular V8 (4.6L, 5.4L)
Apr 21, 2011 08:03 AM
bass4163
1978 - 1996 Big Bronco
Jan 12, 2007 06:28 PM
Powerstroke2000
Alberta Chapter
Nov 12, 2004 12:22 AM
