Sponsored by: Real Truck
Signal Trouble
Old Jul 17, 2013 | 02:52 AM
BUTCHERMAN710's Avatar
BUTCHERMAN710
Signal Trouble
2006 F-250 Super Duty - No turn signals. four way flashers work, wipers work. brake lights work. checked all fuses and relays, even the one above the gas pedal. Replaces the turn signal switch too. Still no turn signals..
any suggestions ????
Old Jul 17, 2013 | 08:37 PM
jakgod3's Avatar
jakgod3
I would check the fuses and relays under the dash first off, and if there are any blown fuses take one out from another fuse slot (make sure its the same amp fuse) and plug it in and see if it works, and the same with relays.. Start there first. In your owners manual it will tell you which numbered fuses. If i'm correct it is fuse 7 (30 Amp), and 18 (20 Amp). Let me know if this helps..
-Jared
Old Jul 17, 2013 | 08:42 PM
jakgod3's Avatar
jakgod3
Whoops, didnt realize you already checked it. It could be the turn signal switch, which is a part of the multifunction switch, or the flasher module. You may need to take it to your mechanic or the dealer if those are the cases so they can test to see if they bad or not.
It is also possible that there is a chaffing wire underneath the dash and not getting a ground.. Just some suggestions
-Jared
cdat81986
18
Sep 14, 2022 08:02 AM
Ordnance
Dec 17, 2013 08:28 AM
77-400-4x4
Mar 4, 2007 03:10 PM
Boltgunner
Feb 19, 2005 08:20 PM
acheers
17
May 7, 2003 08:26 PM
