rear end ratio
Old Jun 12, 2003 | 08:09 AM
ddurant's Avatar
ddurant
rear end ratio
how can i tell what gear ratio my rear is in my 49.
i think it is a 3-92 or 4-27. is it stamped on the housing?
thanks
Old Jun 12, 2003 | 11:50 AM
286merc's Avatar
286merc
rear end ratio
On the glovebox plate similar to the later trucks??
Also stamped on the carrier as a gear tooth ratio.
Worst case, jack it up and count the turns.
Old Jun 12, 2003 | 01:31 PM
51dueller's Avatar
51dueller
rear end ratio
The easiest way to tell is to remove the back cover. Get a rag and spin the ring gear. If it says 47 -12 its 3.92 or 47 - 11 it's 4.27.
Old Jun 13, 2003 | 01:21 PM
51dueller's Avatar
51dueller
rear end ratio
Did you find out what it is?
Old Jun 13, 2003 | 01:35 PM
ddurant's Avatar
ddurant
rear end ratio
Nathan
haven't had time to check
thanks
