The part number you provided is incomplete. The first two digits will tell you the year. First digit is letter=decade, D=70's, E=80's etc, second digit is number=year, so D7 would be 77, for example.
Originally posted by loudfords Your harmonic balancer is from an 84 (or later) truck. I think you might want to check your flywheel part number too if possible.
Can you check this without removing the engine?
And, where is the harmonic balancer part #?
You do not have to pull the engine to get the Part #. It (mine) is located close to the TDC Mark stamped in. You may have to clean it to see the numbers like I had to.
