6.0 troubles
Old Jul 14, 2013 | 08:07 PM
SneauxShoo's Avatar
SneauxShoo
6.0 troubles
I have a 6.0 that I just put a bulletproof oil cooler and sinister egr delete kit into. I have everything put back together and now it won't run. I've checked my FICM and ICP. Both are good. I'm not sure what else to check. Please help.
Old Jul 14, 2013 | 08:11 PM
npccpartsman's Avatar
npccpartsman
Did you put the kit on with the oil cooler that bolts to the condenser?
Old Jul 14, 2013 | 08:16 PM
SneauxShoo's Avatar
SneauxShoo
Yes thats the one
Old Jul 14, 2013 | 08:19 PM
npccpartsman
Did you prefill the cooler with oil prior to trying to start it? Did you prefill the HPO reservoir before you put the BPD adapter plate back on the top of the motor?
Not that it matters, but did you get the kit that now uses the factory filter or the remote filter (older model kit)?
Old Jul 14, 2013 | 08:22 PM
SneauxShoo's Avatar
SneauxShoo
Yes. I prefilled the oil cooler, filter, and the hoses. I didnt prefill the reservoir tho. The guy at BPD said that it shouldnt be a problem afyer cranking it a while. Now im not so sure
Old Jul 14, 2013 | 08:28 PM
2006lariat's Avatar
2006lariat
IPR valve plugged up?
npccpartsman
You should have prefilled the HPO reservoir. It's going to take some cranking to get oil everywhere it needs to be, depending on how far you tore down and what all repairs you did while you were there. Put your batteries on a charger to keep them HOT while you're cranking. Low batteries will kill your FICM. Crank for about 20 seconds at a time and let the starter COOL. How long have you cranked on it???
Old Jul 14, 2013 | 08:44 PM
SneauxShoo's Avatar
SneauxShoo
Ipr was pretty clean when we put it back in. Ive got about 1000 psi for oil pressure. Ive been cranking on it on and off since 10i this morning.
Old Jul 15, 2013 | 01:30 AM
SneauxShoo's Avatar
SneauxShoo
Ok. I filled the reservoir as best I could and the hose that connects to the oil in on the transfer block. The hose was dry. There was no oil flow thru it. I put in about 2 quarts of oil thru the oil in port. Any suggestions?
Old Jul 15, 2013 | 05:15 AM
npccpartsman
How long are you cranking at a time? You've got 1000 psi but you've got a dry hose? Do you have pressure on the dash gauge?
Old Jul 15, 2013 | 06:09 AM
SneauxShoo's Avatar
SneauxShoo
Yea. Pressure on the dash gauge but when I took off the oil in hose, no oil came out and the inside was dry. My duty cycle was 33-38%. I took the ficm fuse out and cranked it about 10 to 15 seconds at a time with 5 minutes of cooldown about 3 times to build pressure. Bled the fuel bowl
Old Jul 15, 2013 | 06:28 AM
npccpartsman
OK--lets start over. Put the fuse back in the FICM, unhook the batteries to clear all the codes (about 10 seconds). Hook everything back up and give it a solid 15-20 second crank then let rest. While it's resting check for any kind of codes.
One other suggestion: you might try pulling the icp sensor plug while you're cranking before you clear everything. It will put the PCM into a default value for HPO and possibly cut some fuel loose to the cylinders. Are you getting any smoke at all while cranking?
Old Jul 15, 2013 | 07:15 AM
mustang_309's Avatar
mustang_309
You say the IPR was clean when you put it back in but have you pulled it and checked the screen for plugging since you have had it all back together and cranking? A lot of times despite your best efforts at cleaning you get something in the HPOP reservoir that clogs up the IPR screen, it can even be something as simple as the lint from paper towels or rags.
Old Jul 15, 2013 | 10:38 AM
npccpartsman
Any updates on getting the truck started?
Old Jul 15, 2013 | 02:49 PM
SneauxShoo's Avatar
SneauxShoo
No, havn't got it going yet. I will pull the IPR and check that out. I do have smoke while Im cranking it
