My new shop
#62
Well here are some more pics....the 2nd to last in the corner pic is the back side support inside my compressor/store room. That way I had more room width wise to work with in the back. It was no fun getting that 6" square pipe thru that hole by hand, by myself.
I used the 4" I beam as a cross piece to support the 24'. After we got the 24' in place, we walked the 4" I beam up 2 ladders and placed it under the 24'x6".
Yes I would of rather used as a top support, so I had full run of the 24', but when working by hand/block and tackle/cable come-along/ratchet strap you do what is some what more easier.
I unloaded a complete 460 with trans and xfer case (under the blue tarp) and even right in the middle of the long span it did not bow one bit. Well maybe just a little....
I plan to concrete the 2 end bays someday. And put in a pit, maybe.
#63
#68
#69
#70
We got the osb on the ceiling. I plan to paint it next & put the lights up. We have been using 500 watt halogen lights. They are blinding. I have 6 four ft double bulb fluorescent units for my lighting. I may add a unit over some tools but I doubt it will be needed. I had 4 four ft units in for temporary lights. They did real good so 6 should be plenty. Having the ceiling white will help. I will post pics
of my progress soon. My osb has imprints of bolts, washers,nuts & drill bits in every piece. It looks like someone spilled a handfull of bolts on the conveyer belt.
#71
#73
Thanks Rich. Its a slow go working alone but the savings allow me to deck it out with the insulation & storage. I plan to build storage under the out feed shelves for my planner,sander & radial arm saw. I will do the same under my table saw extensions & assembly table. Its smaller than I wanted but if I use the space right it will do. I will build a lean too on the side to store lumber & supplies. Its coming along real good. It heats easy. A 115,000 btu heater gets it hot in about 10 minutes. I will take new pics this week.
