Most all had the old r12 till around 1994 or so when the gov mandated using the r134a. You can buy a kit in Walmart to use the newer r134a in your older system. You need to do a lot of reading about it though, education will guarantee you better results in your conversion. The A/C system is like anything else, you need to know a little bit about whats going before you work on it.
