1946 Ford pickup help!
Old Jul 9, 2013 | 06:28 PM
46_ford's Avatar
46_ford
I have a disc brake kit for the front of my truck and a explorer rear end with disc brakes also. My 1st question is what master cylinder/brake booster would i use? I cant seem to find one unless they mount on the firewall, which i dont want. My 2nd question is what manual rack fits my truck? I was thinking Mustang II or pinto
Old Jul 9, 2013 | 06:50 PM
christurney77's Avatar
christurney77
For the brakes, check out my build thread. I went with the standard factory steering. (For now) I just replaced/rebuilt basically everything. It is all like new. I will update in 10 years or so... if you need anything else, just ask.
Old Jul 9, 2013 | 07:00 PM
46_ford's Avatar
46_ford
how much play does the factory steering have??
Old Jul 9, 2013 | 08:15 PM
christurney77
After I rebuilt everything... it has none.
Old Jul 9, 2013 | 08:20 PM
christurney77
Most of the play mine has was in the worm gear. I replaced that, the bushings, the bearings, tie rods, kingpins,and put on front disk brakes. I bought everything but the disk brakes from macs. Got the disk brakes from eBay.
Old Jul 11, 2013 | 08:32 PM
phillip low's Avatar
phillip low
Huh? What? I need links to this stuff.
Old Jul 11, 2013 | 09:23 PM
christurney77
To Phillip low:
"From my build thread"
Your 46 1/2 ton cab looks exactly like my 42 1-1/2 ton cab. I'm thinking that the floor is as well.
Cabs are identical. Frames are different. Fender wells are different as well.
Last edited by christurney77; Jul 11, 2013 at 09:31 PM. Reason: back tracked and saw your pics
natira121
Nov 15, 2018 07:47 PM
pburress
Jan 31, 2012 07:37 PM
bwilliams7527
20
Dec 23, 2007 11:45 PM
Cheapevil
Jun 29, 2004 01:58 AM
Phil In Nashville
Sep 15, 2003 10:51 AM
