Overheating too quickly
Old Jul 9, 2013 | 09:20 PM
Dave145's Avatar
Dave145
Timing is set properly by ear. I do need to get verified by a light. Ill have to check my fan clutch after work tomorrow too.
When the engine is at its normal mid range temperature, the idling RPMS are set to be around 650 and it idles there. However, it does have "dips" where it momentarily drops from 650 to 500. Occassionally it will jump to 900...all without me touching the throttle while its idling normally...however short after these bursts or dips, the engine begins to get really warm...its like the idle speed or the carb in general is still a bit jagged up.
Old Jul 9, 2013 | 09:23 PM
devino246's Avatar
devino246
Those are contradictions. The proper way is with a light.
Old Jul 9, 2013 | 09:28 PM
rogue40's Avatar
rogue40
I'm guessing now but the only thing I can think of that would cause those rpm shifts is fluctuations in your timing. Is the distributor vacuum line connected to the metered port on your carb?
Old Jul 9, 2013 | 10:09 PM
Dave145's Avatar
Dave145
On the freeway, the truck runs great. The temp stays at the N and I can cruise at 65-70 MPH at about 2700 rpms. No misfire or chugging at all surprisingly
Old Jul 9, 2013 | 10:30 PM
rogue40's Avatar
rogue40
That is why I don't think it is your radiator. Once you get enough airflow things work properly. At idle you don't get enough air through the radiator to cool the water in it. This can be caused by a failed fan clutch or too low of an idle setting.
Next time it heats up, rev the engine and hold it at about 2000-2500 and see if it cools down. If it does cool down then the problem could be too low idle rpms. If it doesn't then it is most likely the fan clutch isn't engaging properly and needs replacement..
Low idle rpms could be caused by something as simple as as the idle speed adjustment on the linkage or it could need a proper tune up.
Old Jul 11, 2013 | 07:31 PM
Dave145's Avatar
Dave145
Ok folks I got some stuff to report.
Last night I checked my fan clutch. It is easy to spin cold and hard to spin hot. You can hear it kick in and change rpms with the engine running at different speeds.
I increased my idle rpms from 650 to 800. Made a small difference, but not much in terms of temps.
I will insulate my fuel lines tonight and maybe add my (rather large) carb spacer gasket too.
The ambient air temp today was about 80*. When driving through town, the truck stayed cool and the temp gauge was on the N. When driving on the freeway, it was the same...on the N and fairly smoother running.
When I got to Taco Bell and was waiting in the drivethrough, the temps went up to the R. I then parked the truck and turned it off to eat my lunch. Then when leaving Taco Bell after the truck sat in the sun, the gauge was at the M. It then dropped down to N once I got on the freeway and the truck became happy again.
Sooo...is this normal?? Dad wants to flush the radiator this weekend which I'm afraid may cause more leaks (already have a few pinholes)...any suggestions? Should I buy a new thermostat? The one in the truck has been replaced before but...you know how it goes with PO repairs...
thoughts????
Old Jul 12, 2013 | 10:47 AM
Sooper Camper's Avatar
Sooper Camper
thoughts????
go spend $40 and 2 hours of your time and get a mechanical temp gauge so you know what's actually going on.
Old Jul 12, 2013 | 11:29 AM
devino246's Avatar
devino246
Originally Posted by HIO Silver
I recommend installing a set of gauges or at least a coolant temp gauge for better info than "N-O-R-M-A-L".
x3. You're wasting your time relying on that POS factory gauge.
Old Jul 12, 2013 | 12:27 PM
rogue40's Avatar
rogue40
What you just described is pretty much normal. Also what others are recommending about setting up an independent gauge is very good advice.
I would start looking for a replacement radiator too. Pinholes only get bigger.
Old Jul 12, 2013 | 01:07 PM
AK FORD GUY's Avatar
AK FORD GUY
Agreed 100%
Another thing to consider that is sometimes overlooked.
Your coolant system relies on building and keeping pressure and if the pressure is relieved (pin hole), your temps will increase. The pressure the system is designed to run at has a lot to do with keeping temps in check. That is why a leaky radiator cap can cause a hot temp situation.
Just my $0.02
Old Jul 12, 2013 | 01:42 PM
Sooper Camper
for what its worth, my temps were all over the place when i first got the truck. the factory gauge seemed to be hot one minute, cold the next. i replaced the thermo stat, changed the coolant and added a mechanical temp gauge, and turns out i was alarmed about nothing. the truck was running fine, right at 5* above whatever thermostat happened to be in it (i tried a couple different ones getting it tuned right). even something as simple as air bubbles in the coolant can cause fluctuation in the gauge, and the factory one sucks to begin with.
Old Jul 20, 2013 | 12:35 AM
jbancroft's Avatar
jbancroft
It sounds like a fan clutch on the overheating, if you are not losing any coolant over time. Easy enough to "rent" the little pressure pumper thing from one of the chain parts stores- pump presure in the Rad and see how long it holds . I just replaced a fan clutch that I bought 4 months ago. it was "easy" to spin cold and "harder" to spin hot, but still it was not spinning well. of course, is your fan bolted on the right direction ?
fluctuation in idle sounds like vacum leak- at least mine was doing that (76 f250 with 460) & after I replaced the old lines and 38 year old connectors, it idled fine
evan_nugget
May 3, 2018 10:46 PM
DIYBob
1983 - 2012 Ranger & B-Series
Oct 1, 2017 07:01 AM
annaleigh
Dec 27, 2015 08:35 PM
natewoz
19
Feb 9, 2008 11:36 PM
HOTRODSURFER
Flathead V8 & Flathead 6
16
Sep 27, 2006 06:00 PM
