turn signal indicators
Old Jul 7, 2013 | 11:29 PM
1981Ranger's Avatar
1981Ranger
How do i fix this when i bought the truck last year only the right turn signal indicator worked and now neither of them work please help
Old Jul 8, 2013 | 06:42 AM
Franklin2's Avatar
Franklin2
The front turn lights under the headlights are working correct? If so, take the instrument cluster out, take the bulbs out, and work them in and out of the sockets a few times, and take a pencil eraser and clean the areas where the sockets go against the circuit board. Usually the bulbs are good, it's just bad connections. Check all your bulbs while you are in there and clean them all.
Old Jul 8, 2013 | 10:30 AM
Doug351's Avatar
Doug351
Did this fix your problem?
Old Jul 8, 2013 | 11:27 AM
JayzDaddy's Avatar
JayzDaddy
If the signals work but the dash lights dont flash it should have worked. I have a 86 and i had 7 burnt bulbs between cluster lights and indicator lights. 194 bulbs fit mine. I think older ones take them too.
Old Jul 8, 2013 | 03:17 PM
Doug351's Avatar
Doug351
Well it could also be the flasher, but they usually quit all at once, not one bulb at a time.
Old Jul 8, 2013 | 03:45 PM
JayzDaddy's Avatar
JayzDaddy
Yes it could be a flasher but you are correct if the flasher goes there is no flash
Old Jul 8, 2013 | 08:54 PM
1981Ranger's Avatar
1981Ranger
I'll have to try next time i pull the dash assembly out
Old Jul 9, 2013 | 10:16 PM
1981Ranger's Avatar
1981Ranger
Thank you very much Franklin i took it all apart used a soft pencil eraser to the contacts on the circuit board they both now work wouldnt have done it with out your help since i am still somewhat new to Ford's
F350dog
Dec 2, 2015 05:07 PM
scottlane
21
Oct 4, 2005 08:27 AM
sethro
Electrical Systems/Wiring
Jan 25, 2005 06:44 PM
hugger94
Dec 29, 2004 09:27 PM
GunnerRob
Nov 10, 2003 06:13 AM
