5.8 swap
Old Jul 6, 2013 | 06:32 PM
shoe4849's Avatar
shoe4849
5.8 swap
found an old 81 5.8 with 20k original miles
is it possible to install into a 91 f-250 with a 5.8
will the intake from 91 bolt to 81 block and 81 block to 91 auto transmission
Old Jul 6, 2013 | 06:36 PM
Sapphire Blue_95's Avatar
Sapphire Blue_95
The 351 up to 87' had a carb. Your 90 has a computerized fuel injection system. It can be done, but first, your going to have to get rid of all of the computer components in your current truck.
Old Jul 6, 2013 | 08:08 PM
cjben's Avatar
cjben
or you could swap the computer and other things onto the 81 motor but I'm not sure the 81 cam would be computer friendly and the 81 heads aren't as good as the heads on the 91 engine.
Old Jul 7, 2013 | 08:04 AM
Conanski's Avatar
Conanski
Externally the 351/5.8 engine has not changed since 1971 so all the EFI stuff will bolt right on that motor, but that '81 is a low compression smog era motor so it'll make even less power than the '91 it's replacing.
Borgia
Nov 11, 2015 06:11 AM
weskan
Aug 15, 2013 08:55 PM
F250hoss54
Engine Swaps
13
Sep 19, 2011 08:08 AM
mavman4
Aug 19, 2008 10:41 PM
MattV
16
Feb 25, 2008 07:03 AM
