Need Help
Old Jul 6, 2013 | 10:14 AM
smoore0531's Avatar
smoore0531
Need Help
About a month ago I had antifreeze leaking out from under the manifold. This starts my saga, found oil in the antifreeze so I decided to do the bulletproof upgrade. Did the egr upgrade with stock oil cooler, replaced the faulty o ring to stop antifreeze leak. While I was in there(this process took two weeks cause I really took my time to label and clean everything)I had Ed at FICM do the life time upgrade with eco tune, replaced turbo supply and return oil lines, blue spring upgrade, turbo rebuilt(by local shop here in denver), sinister diesel coolant filter. Everything was going great and it fired up right away. My problem now is that I have no boost, I have checked the map snsor hose and it is clear, took off the intake to turbo and I can turn impeller freely. VGT plug checked and wires to VGT checked for damage, found none. I have a scgII and I am running fine on everything else. What can I check next? Thanks in advance as you guys have basically did this change over for me with all the advise I have gotten.----Stan
Old Jul 6, 2013 | 10:20 AM
mustang_309's Avatar
mustang_309
Assuming everything was working boost wise before you took things apart I would venture to guess you probably have an exhaust leak or maybe one of the CAC boots is leaking. Did you make sure the EBP sensor is plugged in? Its on the drivers side just below the FICM and is attached to the exhaust manifold via a tube, if it is not there it is mounted to the thermostat housing. I would check all of the exhaust connections you messed with and look for leaks.
Old Jul 6, 2013 | 10:25 AM
smoore0531's Avatar
smoore0531
Boost worked great before. Forgot to give the most important part, scgII says p2262, which is=no detected boost mechanical. Dont have any exhaust leaks either.
Old Jul 6, 2013 | 10:32 AM
smoore0531's Avatar
smoore0531
I also had to install a new EBP cause during disassembly I broke it.
Old Jul 6, 2013 | 10:41 AM
npccpartsman's Avatar
npccpartsman
P2262= Map sensor, map hose, cac leak, EP sensor, exhaust restriction or intake leak.
Clear the code and see if it comes back as it could have been stored previously. You might also check the EBP and MAP sensor harness/connections.
Old Jul 6, 2013 | 11:13 AM
smoore0531's Avatar
smoore0531
removed ebp sensor and verified it was correct number on sensor (didnt trust dealer), installed and checked plug, nice and tight. Is there a way to check map sensor? Hot washed the intake when I had it off and probably got something in sensor after start up
Old Jul 6, 2013 | 11:15 AM
smoore0531's Avatar
smoore0531
cleared code and it came back next start up. harness checked on both map and ebp sensors
Old Jul 6, 2013 | 11:23 AM
smoore0531's Avatar
smoore0531
took a resistance reading on the vgt solenoid and got 4.7ohms. is there anyway to check map sensor with scgII?
Old Jul 6, 2013 | 11:53 AM
npccpartsman
I know you said you checked the hose, but did you check the nipple in the intake also?
Old Jul 6, 2013 | 11:54 AM
smoore0531's Avatar
smoore0531
set up scangageII to read psi per prior thread. when I turn the key on and and do not start the motor the psi is at 11.9, I then start the motor and it still reads the same even if I rev it up. Safe to say bad map sensor?
Old Jul 6, 2013 | 11:55 AM
smoore0531's Avatar
smoore0531
yepper checked the nipple too. (thats the best part to me....lol)
Old Jul 6, 2013 | 05:51 PM
npccpartsman
Set it to read MAP, BARO, and EBP. They should read virtually identical at KOEO.
mark_5102
Jun 9, 2019 09:36 PM
Wyatte
Sep 26, 2016 08:23 PM
nylyon
Jun 2, 2011 09:13 PM
dkhollins
Jul 20, 2010 06:32 PM
Robert6401
Mar 11, 2010 08:29 PM
