I've had this truck for a few years. When I bought it I knew it had a bent frame horn. Luckily it's not bent past the radiator support. I would like to straighten it out so I can put the tow hooks back on. It's bent from left to
right about 1 inch. I need a hydraulic porta power to straighten a trailer frame that I have. I want to kill 2 birds with one jack so to speak. Here's my question , finally, Will a 4 ton porta power work or should I get a 10 ton? I know this isn't a normal request but I know some of you will know the answer. Thanks
