Removing Carb Jets?
Old Jun 11, 2003 | 08:40 AM
rebelchic's Avatar
rebelchic
Removing Carb Jets?
I did a search, and didn't see anything that specifically covered this, so I'm going to come out and ask....
I'm currently rebuilding my Autolite 2100 carb for a '69 F-100 with the FE 360. The jets are FAR FAR too small for this truck, and I now realize why I was having so many problems running it... anyway....
I have the carb apart now except for the jets. They're stuck in there, and I can't seem to get them out without stripping the brass. I'm at a loss.... I'm going to have to replace these, so I don't mind trashing them getting them out, I just need them to come out cleanly!
Thanks in advance!
Old Jun 11, 2003 | 10:11 AM
LxMan1's Avatar
LxMan1
Removing Carb Jets?
I would try a small easy out.
Old Jun 18, 2003 | 02:08 PM
Devin 123
Guest
Posts: n/a
Removing Carb Jets?
penetrating oil could help but just a suggestion
Old Jun 19, 2003 | 08:12 AM
rebelchic's Avatar
rebelchic
Removing Carb Jets?
Thanks guys.... I did finally manage to get them out - actually, tried your suggestion of the penetrating oil and it did help some. Carb is back together and on the truck, only now I have another problem.... it's shooting fuel all over my block from the air horn vents.... *sigh*
Old Jun 19, 2003 | 12:27 PM
bubbaf250's Avatar
bubbaf250
Removing Carb Jets?
There is a little wire clip that hooks on both ends of the float pivot pin. The curved middle of that clip must be pushed down, between the wall of the bowl and the inlet valve seat, to engage the groove around the outside of the inlet valve seat. That holds the float in position.
Without that clip securing the pivot pin, the float will not push the needle valve against its seat to cut off fuel flow from the pump, and you will have massive flooding out the main bowl vents.
This is a common mistake for those new to rebuilding the Motorcraft 2150 carb, but it is simple to correct.
Here's a (rough) picture that shows where the float pivot pin retainer clip (yellow) should go.
Old Jun 19, 2003 | 01:00 PM
rebelchic's Avatar
rebelchic
Removing Carb Jets?
bubbaf250,
I understand what you're talking about.... and I remember being sure I had this on correctly, but (hoping the rain holds off), I'll think I'll take another look at it when I get home.
Thanks!
granny_rocket
Jun 29, 2013 07:43 AM
finneys98xj
Nov 26, 2011 11:43 PM
1977F250Custom4x4
Jan 31, 2010 01:48 PM
dhglaser
Oct 1, 2003 11:54 PM
fordmanSLO
Jun 24, 2001 10:17 PM
