4wd steering?
Old Jul 3, 2013 | 10:03 AM
schoo's Avatar
schoo
4wd steering?
Shop manual spect chart use hypoid lube in steering box? That's 4x4truck
Does it leak out the first day or have you guys had better luck?
Old Jul 3, 2013 | 10:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Manual steering gear boxes use steering gear grease, not gear oil...which destroys the seals within a short time.
The reason for the leakage: The sector shaft seal (3591) and the steering shaft seal (3738) are history!
Both are available NOS and I suggest you replace the gasket (3581), sector shaft bushing (3576), steering shaft bearings (3571) and races (3552/3553) at the same time.
The above are basic part numbers. If you want the full part numbers and sources that have them, let me know.
Gear box shown in lower pic:
Old Jul 3, 2013 | 10:24 AM
Buzz44's Avatar
Buzz44
I have never serviced my 2. I Cant be of any help to you Roy.
Old Jul 3, 2013 | 10:42 AM
schoo's Avatar
schoo
ND I agree with you but looking at lubricant chart and specifications in shop man group 21-1 part #c2az-19580-a is what the chart spect calls for
Mine looks to be grease
Old Jul 3, 2013 | 11:01 AM
NumberDummy
Originally Posted by schoo
ND I agree with you but looking at lubricant chart and specifications in shop man group 21-1 part #C2AZ-19580-A is what the chart spect calls for. Mine looks to be grease
Column left, 2nd part number from top:
C3AZ-19578-A .. Steering Gear Lubricant / It's grease, since it comes in a cartridge that's inserted into a hand held grease gun.
Column left, 18th part number from top:
C2AZ-19580-F .. Hypoid Gear Lubricant (rear axle) 90 weight. Same as C2AZ-19580-A except it came in a 120 lb. keg.
Old Jul 3, 2013 | 11:03 AM
schoo's Avatar
schoo
Ok if use FoMoCo special steering gear lube. What is a good substitute?
Old Jul 3, 2013 | 11:06 AM
NumberDummy
You can buy steering gear grease in any auto parts store, but before you use it, the seals should be replaced first.
Ben Quesinberry
Mar 26, 2012 05:20 AM
C-700
Jan 19, 2009 10:20 PM
50flathead
Apr 11, 2007 12:50 PM
tractoman
Feb 21, 2006 02:25 PM
