Overheating, need help
Old Jul 2, 2013 | 08:49 PM
EXv10's Avatar
EXv10
Originally Posted by lmassmann
I just got what O'Reilly had in stock, its a 185deg. Yes there is antifreeze in it. & no doesnt lose any. Just topped it off for first time in 3 yrs & it hasn't moved at all since.
I just put what O'reillys had in stock in and it opened at over 200* and the bottom valve part was too long. You need to put a Mtrcrft one in in this case to eliminate that problem for starters, they are more sophisticated nowadays with the 2 valves and all. Clean the face of the rads and straighten the fins, you can remove the cover above to get at it better. Don't bend the fins with high pressure water.
Old Jul 2, 2013 | 11:07 PM
lmassmann's Avatar
lmassmann
Thanks for all the suggestions, I will be working on it this wknd.
Ron1999
1997 - 2003 F150
Jul 1, 2015 12:19 PM
Hossrod
May 22, 2013 11:23 AM
Callandscaper
Modular V10 (6.8l)
Jul 31, 2012 11:22 AM
eddiedebb
Jun 11, 2011 10:07 PM
Guido01
1978 - 1996 Big Bronco
Nov 16, 2001 10:27 AM
